Surge Protector Of GFCI? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2013, 09:50 PM   #1
Rewards Points: 552
Surge protector of GFCI?
I just had a water softener installed. I want to use a GFCI outlet in the garage, but it's already being used by our refrigerator and a Verizon FIOS backup device.
I found a pretty neat solution that turns 2 outlets into six, but the device is also a surge protector. Are there any issues with installing a surge protector on a GFCI circuit?
kcrossley2 is offline   Reply With Quote
Old 08-05-2013, 10:07 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,922
That should be fine. In the event of a surge, the GFCI will trip because of the way the surge protector works. But that should not be a problem.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 08-05-2013, 10:10 PM   #3
Msradell's Avatar
Rewards Points: 172
You may want to consider running a separate circuit that doesn't have a GFCI for the refrigerator. A refrigerator can be used without a GFCI and if you have one and it trips you lose everything in the refrigerator without knowing it.
Msradell is offline   Reply With Quote
Old 08-05-2013, 11:24 PM   #4
Oso954's Avatar
Rewards Points: 1,018
Not in a garage. The GFCI is required.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
mpoulton (08-05-2013)
Old 08-06-2013, 12:09 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
As noted above....GFCI required....but how come you just don't wire some additional outlets off the load side of the GFCI?
GFCI after dimmer switch curiousB Electrical 16 04-08-2013 04:18 PM
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 08:43 AM
GFCI - White & Black Both HOT? hagler Electrical 11 03-19-2012 08:29 AM
Ungrounded GFCI + Surge Protector squigish Electrical 4 08-16-2009 04:45 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
