-   -   Surge protector of GFCI? (http://www.diychatroom.com/f18/surge-protector-gfci-184832/)
kcrossley2 08-05-2013 09:50 PM
I just had a water softener installed. I want to use a GFCI outlet in the garage, but it's already being used by our refrigerator and a Verizon FIOS backup device.
I found a pretty neat solution that turns 2 outlets into six, but the device is also a surge protector. Are there any issues with installing a surge protector on a GFCI circuit?
mpoulton 08-05-2013 10:07 PM
That should be fine. In the event of a surge, the GFCI will trip because of the way the surge protector works. But that should not be a problem.
Msradell 08-05-2013 10:10 PM
You may want to consider running a separate circuit that doesn't have a GFCI for the refrigerator. A refrigerator can be used without a GFCI and if you have one and it trips you lose everything in the refrigerator without knowing it.
Oso954 08-05-2013 11:24 PM
Not in a garage. The GFCI is required.
ddawg16 08-06-2013 12:09 AM
As noted above....GFCI required....but how come you just don't wire some additional outlets off the load side of the GFCI?
