Surge Protected Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2007, 11:35 AM   #1
rjr
Surge protected breakers
Any ideas where to find a single pole 20 amp spike suppressing breaker for a Square D panel? I've been to local hardware stores,as well as,Home Depot and no luck so far. They only have ground fault equipped ones......HELP!
rjr is offline   Reply With Quote
Old 06-30-2007, 12:14 PM   #2
Rewards Points: 1,450
My first question is:
For what purpose do you need this? Exactly what are you trying to protect?
ktkelly is online now   Reply With Quote
Old 06-30-2007, 01:41 PM   #3
rjr
re: surge protected breaker
safeguarding audio/video components in limited space, which is the reason a wall plug-in strip type will not suffice........the answer please???
Old 06-30-2007, 02:45 PM   #4
Home Improvement Guy
ron schenker's Avatar
I would install a whole house surge protector at the panel. Sounds like overkill, but for about $125 you never have to worry about spikes, lightning, etc. Electrical supply houses will carry them. "Leviton" is common in my area.
ron schenker is offline   Reply With Quote
Old 06-30-2007, 02:54 PM   #5
rjr
Ron,
thanks for the info.... I'll check into it.
Old 07-02-2007, 10:12 PM   #6
Okay, I must disagree....
A whole house surge, while a good thing, will NOT do what you need.
Why?
A power surge (think nearby lightning strike) can, and will, enter your AV equipment via the cable line or telephone line (if connected to a phone line) even if you have a whole house surge unit. That "whole house surge" won't stop a power surge from entering in that manner.
Instead, get yourself a good Panamax line conditioner/surge protector that allows for those lines to be routed through it. Something such as the Panamax M4300-EX at the low end, or if you have a DVR and/or a DLP/LCD TV, the Panamax Max-1500 UPS.
Check out http://www.panamax.com
I'm in the "professional" AV business, and I wouldn't do it any other way..
Old 07-02-2007, 11:53 PM   #7
Contractor
Dan101's Avatar
I have to agree with ktkelly. If you are protecting video equipment, you have to have something that will block every available point where lightning or spikes could enter your system.
I recommend Panamax and/or Furman for all my customers when building home entertainment centers. Furman power conditioners can be found at: http://www.furmansound.com/
Dan101
Owner
J.& D. Remodeling
Chicago, IL
Dan101 is offline   Reply With Quote
Old 07-03-2007, 01:22 PM   #8
Rewards Points: 58
If lightning hits your house, there is NOTHING you can do to protect your equipment. Just use a high quality surge suppressor and unplug the equipment during periods of lightning and thunder storms.
Nothing can stop a direct lightning strike.
Old 07-04-2007, 10:52 AM   #9
J.V.
Sorry, but I cannot agree.
I have personally seen a high quality (not some cheap $9.95 unit) surge protector, such as a Panamax unit, save the equipment in the case of a direct lightning hit on a home.
Lightning entered the home through the low voltage wiring going to a birdbath fountain. The surge took out the garage door opener, electronic range controls, refrigerator electronics, microwave, HVAC controls, sprinkler controls, telephones, clock radios, etc, etc.
This lightning strike was so powerful that it actually blew a few switches and receptacles completely out of the wall. Exited the structure via the TV antenna that was suspended from the roof rafters. Blowing the antenna to pieces, as well as blowing a decent size hole in the roof.
Entire Home Theater System was found to be in perfect working order after the electrical wiring was repaired, and the surge proterctor was replaced.
Best to "Never say never"
Old 07-04-2007, 01:49 PM   #10
Rewards Points: 58
ktkelly,
I would say that this was just luck. However, your explanation does lead me to believe that it MAY be possible to protect ones equipment. But as far as a direct lightning strike all bets are off.
A direct strike does not have to enter and destroy from the wiring. Everthing in the house is in jeopardy.
So the system you mention in your post is rated to withstand the ensuing fire too?
This is just my opinion.
Old 07-05-2007, 10:10 AM   #11
JV,
There's not always a fire.
The first time I ever saw where lightning had run through a house it was somewhat unusual.
Riverfront house in Ohio sat dead center on the lot, big tall oak trees on all four corners of the lot. Party lights were strung from the trees to the wrap around porch corners.
Lightning hit one of the oak trees, ran through the party light wiring, blowing out all the bulbs (like flashbulbs going off), before entering the structure.
The lightning then followed the wiring around the porch to the other side before exiting down the party light wiring on the other side, and again blowing out bulbs as it headed to the oak tree on the far corner.
At the same time, the lightning burned a trail up (literally blistered the paint)the side of the house, across the ceiling of the second floor rooms, before joining the other trail exiting the structure.
The tree that took the initial hit has a bright yellow stripe from top to bottom. There was a bright yellow line burned in the lawn, following the path of the party lights, and this bright yellow path trailed through the crawl space UNDER the house as well.
The oak tree where the lightning exited had a bright yellow line from bottom to what was left of the top (it was blown apart).
Everything electrical in the house was blown. All the light switches and receptacles were physically blown out of the walls. Everything electrical was done in.
No fire... And the people that were in the house were fine, other than being scared to death..
Luck?
I don't think so....
Zinsco breaker boxes and breakers. evosounds Electrical 3 07-29-2007 07:08 PM
1/2" breakers Clutchcargo Electrical 3 06-22-2007 07:28 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
integrating electrical surge protector into wall? aznboi04k Electrical 3 11-23-2005 11:01 AM
Point of Entry Surge Suppression Question eltrigo Electrical 1 06-02-2005 07:14 PM
