Surface Mounted Panel. How Insulate Before Closing Wall. - Electrical - DIY Chatroom Home Improvement Forum
Old 09-20-2009, 12:56 AM   #1
Surface mounted panel. How insulate before closing wall.
hello. i have a new cottage. right now the walls are 2x4 construction. osb on the outside and nothing on the inside.
i am doing the insulation and poly myself and then the builder is putting on the drywall and then electrican will put the panel on (surface mounted).
there are wires running down from the rafters and just end within the wall space. i believe that these wires are what the electrician will use to attach to the panel, but how do i insulate and poly the wall?
I HOPE THIS MAKES SENSE BUT IF IT DOESNOT PLEASE ASK ME QUESTIONS. I NEED HELP!!!!!
bobwaters is offline   Reply With Quote
Old 09-20-2009, 05:38 AM   #2
Whatamess
Just pack fiberglass in around the wires and he can work them from there. Your other option you could wait until the electric is finished and kill the power loosen the box and spray foam insulation behind it. I would go with the first choice.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 09-20-2009, 10:57 AM   #3
Rewards Points: 160
Leave that space open. Don't do anything in that bay until the electrician is done.
If it worked before you worked on it. You did something wrong.
How to fasten service panel to stucco wall? RxScram Electrical 9 10-28-2011 12:37 PM
Passing wire to another panel theatretch85 Electrical 5 09-20-2009 11:09 PM
Using OSB for wall surface around furnace and hot water tank kandony Building & Construction 7 07-02-2009 07:38 PM
Wall mounted scart / aerial socket miked Electrical 5 01-05-2007 05:40 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
