Surface Mount Outlets And Grounds - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 09:45 PM   #1
Surface mount outlets and grounds
Hi everyone.I will be adding 4 outlets to my basement using surface mount metal tracks and outlet boxes.I will be drilling through the garage wall to tap into my sub-panel for power.I will be using 12/2 wire with a ground .The track will make an L with the outlets spaced 8 feet apart on each wall.The metal surface box has the green ground screw on the back plate.The outlets also have the green ground screw.Where should I attach the bare copper wire? To the back plate or the outlet or pigtail them together?Also is a 15 amp breaker enough?This area is a guest room that will see very little use.The outlets are so that I can connect a table lamp or 2,a clock and a cell phone charger,Thanks.
ps when drilling through the block wall I believe I need to pass a small section of conduit through the hole,yes.
nel262 is offline   Reply With Quote
Old 01-25-2010, 07:41 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Sounds like you're using wiremold. Not sure if it complies with 250.146 so I'll just say, where the wire enters the box, wrap the bond screw with the ground and make a pigtail off to the receptacle.
Where you penetrate the garage wall, it may be a firewall so, you'll need to maintain that rating.
Sounds like this circuit may also require AFCI protection.
Don't forget smoke detectors,(in the room and adjacent to the outside of the room preferably tied into existing smokes) and if you don't have a ceiling light you'll need to have at least one switch controlled receptacle.
wirenut1110 is offline   Reply With Quote
Old 01-25-2010, 08:50 AM   #3
Rewards Points: 1,418
When you run a ground wire through the conduit and bond the ground wire to each metal outlet box, then the system is adequately grounded.
Each receptacle or switch, etc. must be grounded using a pigtail to the ground wire or metal box, or by using a special grounding clip at one of the mounting screws if a metal box was used..
Old 01-25-2010, 11:02 AM   #4
This is an existing room with overhead lighting and other existing outlets.The NEW outlets are for convenience,I'll need an outlet on either side of a bed and near a desser.The hole I need to drill will be about 3/4 in dia. for the 12 inch piece of conduit[block wall] then run bx thru.
Old 01-25-2010, 11:05 AM   #5
That is the way I plannned on doing it,attach the copper wire to each box and pig tail to the outlet.thanks.Now I need to borrow a hammer drill!
Old 01-25-2010, 12:01 PM   #6
Licensed electrician
Rewards Points: 1,054
There is no need for the conduit sleeve thru the block.
Old 01-25-2010, 05:02 PM   #7
Is an AFCI wired the same as an ordinary circiut breaker?
Old 01-25-2010, 05:04 PM   #8
No, AFCI breakers are wired just like GFCI breakers
Old 01-25-2010, 09:51 PM   #9
Which is how?
Old 01-25-2010, 10:13 PM   #10
Thumbs up
There are 2 rental outfits on Ft. Hamilton Parkway. A few blocks apart. (Can't be more specific, 'cause it'll no longer be in the category of advice.!
spark plug is offline   Reply With Quote
Old 01-25-2010, 10:55 PM   #11
Old 01-26-2010, 09:43 AM   #12
Thanks,I think I found one.
Old 01-26-2010, 10:25 AM   #13
One more question,can I just run the track horizontal with an outlet in line or do I need to have the outlet above the track,hence making a right angle? Looks much neater in a straight line.TIA
Old 01-26-2010, 12:49 PM   #14
Thumbs up
Yes, you can. The Wiremold boxes have cutouts on both sides and top & bottom to facilitate doing just what you had in mind!
Old 01-26-2010, 05:52 PM   #15
I figured as much.It's just every pic I've seen of the installation they have the track running horizontal then it makes a right angle turn upwards and then the box.Too much track for me.I like the look of one clean line,especially since i reallly don't care for the wire mould in the first place.
Testing an Installation: Accidental Grounds and Continuity Bocolo Electrical 24 02-10-2009 02:06 PM
GFIC / Grounds pearlbeer Electrical 5 09-03-2008 03:40 PM
replacing old outlets and switches Nailpounder Electrical 7 04-28-2008 10:36 AM
