Surface Mount Of New Service. Cable Protection - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2011, 09:31 PM   #1
Surface mount of new service. cable protection
I am mounting a new service panel. It is in an ICF house and is surface mounted on plywood. What are the rules for running romex to the panel and using "SE" cable exposed. Someone told me that as long as the cables are over 7' high no protection is required. What is the rule ? Can I run romex tacked to the plywood so long as it is fastened or must it be covered?
Thanks in advance
brianpk is offline   Reply With Quote
Old 05-22-2011, 08:39 AM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,882
I just needs to be fastened. If closer to the ceiling, you can leave loose where it enters the top of the box.
New service Help (Meter can/ service mast Conduit help) cwolford Electrical 13 03-26-2011 08:55 PM
Ground Wire with Service Cable OK? i_need_help Electrical 1 02-18-2011 11:53 AM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 09:39 AM
Overhead Service - SER Cable robertmee Electrical 21 10-14-2007 07:25 PM
upgrading service cable Clutchcargo Electrical 1 06-22-2007 11:04 AM
