Surface Mount Box For Coaxial Cable? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2013, 08:29 PM   #1
Rewards Points: 1,622
Surface mount box for coaxial cable?
I have seen some phone jack box that's raised that you can surface mount onto sheetrock or baseboards.
Is there the same sort of thing for coaxial cable? I searched around and couldn't find one.
miamicuse is offline   Reply With Quote
Old 09-15-2013, 08:35 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Yes, I know Menards carries them. They are empty boxes and you buy the actual jacks and snap them in. P&S makes them.
Old 09-15-2013, 08:36 PM   #3
Rewards Points: 13,456
There available but why would you want to?
Going to look a whole lot better and not look like an after thought if it's run through the wall.
Old 09-15-2013, 09:02 PM   #4
Because I don't care how it looks it's a newly acquired apartment that I am tidying up for rental and since I am running the coaxial cable along the top of the baseboard already (which also look like an after thought), that's the best I can do given the time budget I am allocating to this, about 30 minutes. No time to cut holes in wall fishing through studs and patch, sand paint etc.
The Following User Says Thank You to miamicuse For This Useful Post:
stickboy1375 (09-16-2013)
Old 09-15-2013, 09:25 PM   #5
Do a key word search on wire molding.
Lowes and HD both have a whole section near the electrical dept. with the moulding and outlets.
Old 09-16-2013, 08:19 AM   #6
Rewards Points: 236
just do that, and leave the end, say 6", hanging.
Fix'n it is offline   Reply With Quote
Old 09-16-2013, 08:32 AM   #7
PoleCat's Avatar
Rewards Points: 1,646
Wire Mold has a nice selection of surface mount boxes and conduit. I used them extensively in offices to corral computer cables.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Extending and covering phone cable in closet Dorado Electrical 5 03-28-2013 10:09 AM
Running data cat5 cable in walls fdmillion Electrical 2 01-17-2013 07:15 PM
Aerial Cable to Garage & Adding Sub Panel CDW59 Electrical 5 12-09-2011 06:43 AM
Electrician best practice questions mudworm Electrical 32 11-12-2011 01:59 PM
Short ciruit with Romex 10/3 cable and cable connectors virago Electrical 21 10-07-2011 08:01 AM
