Surface Box For Light - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 11:30 AM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Much better!
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
jamiedolan (06-01-2011)
Old 06-01-2011, 12:00 PM   #17
Licensed electrician
Rewards Points: 1,634
I don't understand why you still had to drill a large hole for the connector. Could you not have brought the cable into another KO?
Old 06-01-2011, 01:02 PM   #18
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
I could have used any of the KO's for the clamp & romex; but I had to make a hole somewhere for the cable to go through and the clamp to sit up in. I think the clamps are right about 7/8" or 1" across. I only drilled a 1-1/4" hole, since I mounted the box on the ceiling surface, there would have been no where for the clamp to go if I didn't have that size hole.
Thanks.
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 06-01-2011, 01:12 PM   #19
DIY'er
jamiedolan's Avatar
All Done -- almost
All done, I think they look nice. They have those crystal style bulbs in 60 watt. I have to connect them into a junction box in the attic and wire them up. I have to pull over a 15a circuit for them because everything I have up there is 20a, no big deal, It is only about 10' from a panel.
I'm going to put a Decora style dimmer on them, man are those Decora style dimmers expensive.
View from outside ( I think it looks really nice to see the fixtures in the windows like this; I think I'm going to do the same thing in the other part of the kitchen by the front windows).
I still have 4" cans I'm planning on installing in the sofit boxes; not sure how much I need them even, the single one of these threw off a lot of light, now with the 2 side by side it should be pretty bright in that part of the kitchen. I think I will still do some cans, in case we need extra light over the counter area.
Thanks!!
Jamie
Old 06-01-2011, 01:24 PM   #20
Rewards Points: 512
Looks like a good job, but I'm with Jim, I still don't know why you couldn't have used one of the knockouts
Old 06-01-2011, 01:48 PM   #21
The boxes are surface mounted, not recessed flush with the plaster. I thought a hole had been drilled into the bottom of the joist. I was mistaken.
Looks good.
Solid Surface vs Granite and Quartz jbeall General DIY Discussions 26 03-15-2011 03:49 PM
Is a door slab still paintable if the surface is dirty? darsunt Building & Construction 4 12-19-2010 05:26 AM
Preparing Surface for Seeding pumpkinpatch Landscaping & Lawn Care 9 09-07-2010 03:15 PM
Surface mounting breaker box Nhrafan Electrical 3 04-09-2008 02:16 PM
Another name for surface wiring/wire-mold? fw2007 Electrical 4 01-09-2008 04:56 PM
