Supporting Romex - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 07:50 AM   #1
Rewards Points: 135
Supporting Romex
I'm running some 110v wiring from outlet to outlet exposed on concrete block in my basement. I have the galvanized clips to support it. How often are they required to be spaced? I know there is also another requirement to support it just before going into the box, what is that spacing? Thanks!
smata67 is offline   Reply With Quote
Old 05-02-2010, 08:40 AM   #2
Rewards Points: 1,192
8" to box,then every 4 ft. Try conduit?
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
waterman1971 (05-03-2010)
Old 05-02-2010, 03:09 PM   #3
Electrical Contractor
kbsparky's Avatar
If the box has a connector, or built-in clamps, then the first strap can be up to 12" away. Type NM cable must be supported at least every 4 feet thereafter.
334.30
-KB
Old 05-03-2010, 09:08 AM   #4
Originally Posted by bobelectric View Post
Try conduit?
That's what I was thinking. Does code even allow NM installed exposed on concrete block (where it's easily reachable by the average person)? I thought NM cable had to always be protected in one way or another... either burried in a wall, or surface mounted to some place not typically accessed (like a crawl space or attic) or up out of reach in an exposed basement?
HooKooDooKu is offline   Reply With Quote
Old 05-03-2010, 09:45 AM   #5
Just call me Andrew
Rewards Points: 1,020
Try conduit?
If you run a long distance in conduit, you should use THHN/THWN wire (individual black, green, white) instead of romex. I think the rule is that for a short run, you can put romex in conduit to protect from damage, but over a longer distance run, it should be individual strands.
Do I have that right?
Andrew
secutanudu is offline   Reply With Quote
Old 05-03-2010, 11:09 AM   #6
As long as the conduit is sized large enough for the romex it is OK & meets code
(3) #12 THWN need 1/2" conduit
(1) 12-2 cable (.450") will also fit in 1/2" & meet code
But the 12-2 will be a PAIN to pull thru any distance
I sleeved 12-2 UF in ~8' of conduit to go into a storage area junction box
From there I went with THWN in the conduit
I did not want a complete run of conduit back to the sub - also a pain
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 12:07 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 01:53 PM
Connecting Romex at Panel Bocolo Electrical 14 02-21-2009 05:55 AM
Running Romex Bocolo Electrical 6 02-20-2009 09:58 AM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 05:01 PM
