Supporting NM-B - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2012, 11:47 AM   #1
Rewards Points: 135
Supporting NM-B
I'm going to install 1x4 runners at the bottom of joists in my basement to support 12/3 cable, rather than drill holes. How often do I need to support it along the runner?
smata67 is offline   Reply With Quote
Old 06-08-2012, 12:13 PM   #2
Licensed electrician
Rewards Points: 1,262
At intervals no more than 4.5 foot apart and within 1 foot of any box with a clamp or connector. The cable would need to be secured within 8" if there is no clamp.
Need advice -home inspector pointed a problem - metallic pole not supporting beam skRyan Building & Construction 28 02-28-2012 10:46 PM
Supporting Concrete Slab from Underneath? Yippydadada Building & Construction 5 10-18-2011 05:24 AM
wet slab/wet supporting beam/drywall mhemming Building & Construction 0 06-10-2011 12:57 PM
Supporting Garage ceilings joists above garage for supporting storage weight. glexguy Building & Construction 1 03-10-2011 02:12 PM
Supporting a cathedral ceiling jmpn Carpentry 4 06-01-2009 11:29 AM
