Supporting An Indoor Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-03-2008, 09:31 PM   #1
Supporting an Indoor Breaker Panel
I have almost completed the installation of the upgraded service in my older home and have installed a new meter socket, ran new 2/0 conductors from weather head to socket and drove in a new ground rod running #4 copper from the ground terminal in the meter socket to the rod.
Now my next question, here's a pic of the new panel I placed inside, which is back-to-back with the meter:
My question is, what's the best way to support the panel when there is a slight gap on both sides of the studs? Should I place a spacer there and then screw it in? I have to be sure the edge of the panel is flush with the finished wall so that I can install the cover on it properly.
Next question, since the panels are back-to-back of each other, I have used a 3" rigid metal nipple conduit to connect them and have used plastic bushings to protect the conductors from insulation damage. Now, I have read that its better to use the metal grounded bushings on the ends and connect the ground to the panels on their respective sides.
Will that mean I need to install the metal ground bushings in place of the plastic ones, and connect the related ground wire to the panels (called bonding)?
One last question, after the new service is installed, is it common or uncommon to energize the new panel before installing the new breakers? Some electricians say yes, some say no. The main would be off of course before setting them in, but since my house needs a rewire (have alot of old rubber-insulated wire thats worn away) and will need to connect a temporary outlet to the panel until the job is complete. And in my county I do not have any inspectors nor am I required to obtain any permits.
What are your thoughts? Thanks for any help!
AVTechMan is offline   Reply With Quote
Old 11-04-2008, 06:27 AM   #2
Licensed electrician
Rewards Points: 1,610
Use some thin wood strips to fur out the stud to the side of the panel.
You cannot just use the plastic bushing to connect the nipple to the panel. The bushing are used in conjunction with the metal locknuts.
Even with the main breaker off there are still live parts in the panel that you can contact either with your hands or the wires as you cut them into the panel.
Old 11-04-2008, 07:06 AM   #3
Rewards Points: 506
Send a message via AIM to theatretch85
Jim Port- I believe the OP is referring to the special metal bushings that have the grounding lug attached and have the plastic insert in the center to protect the wires as you pull them through the conduit.
Like this:
theatretch85 is offline   Reply With Quote
Old 11-04-2008, 07:27 AM   #4
If you do install a temp outlet, any knockouts knocked out must be blocked again.
rgsgww is offline   Reply With Quote
Old 11-04-2008, 01:07 PM   #5
Like this:
This is correct. I already do have the locknuts in place with the plastic bushing behind it. I was referring to the special metal bushings with the ground lug for both sides in order to bond them together with the ground. My water line coming in the house is PVC and my meter is in the front yard near the street.
Old 11-04-2008, 03:38 PM   #6
You do know that you need to sink 2 ground rods, right?
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 02:05 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
