Supporting Emt From 4s Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 12:24 PM   #1
liscenced electrician
Rewards Points: 538
supporting emt from 4s box
I'm sorry this isn't really a diy question but its electrical code none the less. I'm about to start lighting on the project I'm on. I was told to mirror what some other guys did in another section. They supported their 4 square box from a strut rack. They didn't want to build anything to support their emt within 3' of the box so they just attatched a bar hanger to the 4s box. The emt that goes in to the box is supported by that bar hanger. They claim its legal and I'm having a hard time buying in to it. They say the bar hanger is solid, therefore its legal
jimmy21 is offline   Reply With Quote
Old 03-30-2012, 12:34 PM   #2
Rewards Points: 58
358.30(A) You are correct. The conduit should be strapped within 3' of the box. But your co-workers are doing something we all have done in the past.
Check the exception. Is this why they can do it?
Old 03-30-2012, 01:50 PM   #3
Rewards Points: 538
I dont have a codebook with me. Can you tell me what it says? Is that just where it says secure your pipe within 3' of the box? The pipe is supported. The pipe is supported by the bar hanger, the bar hanger is supported by the 4s box and the 4s box is supported by strut.
Old 03-30-2012, 03:06 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
I agree with John(shocking I know) but I'm sure it has be done that way, even if not compliant.
The execption states you can increase to 5' of unbroken pipe where structural members do not readily permit fastening witin 3'.
jbfan is online now   Reply With Quote
Old 03-30-2012, 03:27 PM   #5
Rewards Points: 538
I'm not asking about distance. I'm saying the pipe is litteraly supported from the 4s box. There is no ruling against this?
I wish I could take a picture but there are no cameras allowed unless you have a camera pass
Old 03-30-2012, 04:23 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I think I can picture what you are describing and I don't see an inspector going for it if that is the only means of support within the first 5 feet.
Old 03-30-2012, 05:11 PM   #7
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Acording to this
Exception No. 1: Fastening of unbroken lengths shall be
permitted to be increased to a distance of 1.5 m (5 ft) where
structural members do not readily permit fastening within
900 mm (3 ft).
As long as the 4s is supported and the pipe within 5 feet it should be allowed.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-30-2012, 09:21 PM   #8
Rewards Points: 538
i drew a little picture. Should be able to figure out what i mean
Old 03-30-2012, 09:30 PM   #9
jbfan's Avatar
Rewards Points: 142
I have seen those.
It has a clamp on both sides of the box that attaches to the pipe.
I think caddy makes them.
Old 03-30-2012, 09:34 PM   #10
jbfan's Avatar
Rewards Points: 142
Check this out.
http://www.erico.com/products/CADDYc...ConHangers.asp
The Following 2 Users Say Thank You to jbfan For This Useful Post:
PaliBob (03-31-2012), zappa (04-01-2012)
Old 03-30-2012, 10:14 PM   #11
Rewards Points: 538
Originally Posted by jbfan View Post
Looking at that, I don't think they are using the product as intended. I think they are intended have their own support. I'm pretty sure for them to be legal the bracket would need to be mounted to the strut and then the box and pipe mounted to the caddy bracket
Old 03-30-2012, 10:22 PM   #12
jbfan's Avatar
Rewards Points: 142
If that bracket is not secured to the strut or the bar joist, then it isn't legal
Old 03-30-2012, 11:43 PM   #13
k_buz's Avatar
Caddy makes everything for just about any situation you can imagine...nice find.
Old 03-30-2012, 11:43 PM   #14
Rewards Points: 538
don't know what a bar joist is, but the caddy bracket is only supported by the 4s box.
Old 03-31-2012, 12:04 AM   #15
rrolleston's Avatar
What is the strut rack attached to? Sounds legal if the bar hanger and box are attached to the strut.
Need advice -home inspector pointed a problem - metallic pole not supporting beam skRyan Building & Construction 28 02-28-2012 10:46 PM
Supporting Concrete Slab from Underneath? Yippydadada Building & Construction 5 10-18-2011 05:24 AM
wet slab/wet supporting beam/drywall mhemming Building & Construction 0 06-10-2011 12:57 PM
Supporting Garage ceilings joists above garage for supporting storage weight. glexguy Building & Construction 1 03-10-2011 02:12 PM
Supporting a cathedral ceiling jmpn Carpentry 4 06-01-2009 11:29 AM
