Old 05-26-2008, 04:34 AM   #1
Post
Supplemental RV Pedestal Installation
This project consists of digging a 24" trench to lay down the direct bury power supply from our existing home meter and the installation of a RV power pedestal (50/30/20 amp). Purpose for the single pedestal is for company with 5-wheel/motor home.
We are planning on using a 4-wire flexible mobile home feeder wire suitable for direct burial w/ sweeps at both ends.
Questions:
What size feeder wire should we use?
With current prices, should we use copper or aluminum?
We live in lightning country, does the pedestal require a separate grounding electrode?
Thank you for any help or suggestions you may make.
Last edited by Helitac; 05-26-2008 at 04:38 AM. Reason: embedded font commands show in draft
Helitac is offline   Reply With Quote
Old 05-26-2008, 07:07 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
1) Depends on the distance. Under 200' you can go #6CU.
2) If by lightning country you mean the southeast, I'd definitely go with copper. It's a good idea any way.
3) I assume this pedestal has breakers to distribute the load to the different amperage receptacles. You definitely need a ground rod at this remote panel.
Old 05-26-2008, 12:07 PM   #3
Around these parts, a supplementary grounding electrode at the RV pedestal is not required (http://www.cbs.state.or.us/bcd/programs/electrical/2008_electrical_interps/el_interp_RV_Pedestals.pdf), but may be installed if desired. The AHJ in your location may or may not see things the same way. It's probably a good idea to install the supplementary rod at the pedestal if you're in lightning country, even if it's not required.
Matsukaze is offline   Reply With Quote
Old 05-26-2008, 12:55 PM   #4
If it is a remote sub-panel a grounding electrode IS required.
If it is just an RV receptacle no electrode is required, but a supplementary electrode could be used, not that it would do very much.
From the sound of it, "(50/30/20 amp)", this is a panel, not just a 50A receptacle.
Old 05-26-2008, 05:38 PM   #5
The interpretation I linked to would not apply to the original poster's situation since he is just setting up a space for one RV and not building an RV park. But, if it were a park, all the RV pedestals and the service feeding them would be considered to be a single structure. I have to wonder how many other AHJ's would stretch the definition of "structure" that far.
Old 05-27-2008, 09:40 PM   #6
We live in the mountains of western Montana which sees a lot of lightning.
Since the single RV pedestal will be located approximtely 150' from the meter, I will be putting in a panel, with a disconnect and individual breakers for 50/30/20 amp circuits.
Any ideas on where someone could pick up a prewired RV pedestal? Local hardware, Lowes and HD aren't familiar with what I need. Otherwise, I'll be back because I will have to make it myself.
This chat is great because it is really helpful in bringing up things one may not have thought of. I appreciate the exchange of ideas. Thanks!
Old 05-27-2008, 09:44 PM   #7
Master Of Nothing
mr500's Avatar
Try
http://www.rvpedestal.com/
http://www.rvpoweroutlet.com/
Go to google type in RC Pedestal and BAMMO
Im Not An Electrician...But I Did Stay At A Holiday Inn Express Last Night!!
mr500 is offline   Reply With Quote
Old 05-27-2008, 11:14 PM   #8
Idiot Emeritus
I looked one up in the Square D catalog, it has a 50 amp, a 30 amp, and a 20 amp receptacle in it, along with the associated breakers. It's pedestal mount too.
It's a class 1140, catalog #PAK75G. The 20 amp recpt is GFI protected, if you want the 30 amp one GFI, add 'FI' to the end of the catalog#. This is a 2003 catalog (the current one is in my van, it's raining out, and I'm just too friggin lazy to go get it! lol), the list price is $671. The company I work for usually gets stuff like this for about 1/2-2/3 list.
Rob
micromind is offline   Reply With Quote
Old 05-29-2008, 02:23 AM   #9
Thank you all for the help! An RV park owner referred me to the person who installed the pedestals in his park. He in turn referred me to a electrical warehouse, where I purchased a pre-wired 50/30/20 amp box.
The wholesaler was willing to sell me the flexible 4-wire but they thought the #6CU was a little light for the distance. I'll chase that down tomorrow.
Appreciate all the help you have provided. Thanks!
Old 10-17-2009, 11:07 AM   #10
I'm doing the same thing as you. I have already got the Pedesta but I still need to get the wire. Does any body know where I can buy the wire around Billings, Montana?
Dairygoat is offline   Reply With Quote
Old 10-17-2009, 11:51 AM   #11
let me that for you
Old 06-03-2011, 09:29 PM   #12
I'm looking for instructions for hooking up the earth ground in a milbanks u5240 pedestal installation.
megronniger is offline   Reply With Quote
Old 06-04-2011, 03:20 AM   #13
Scared Electrician
Saturday Cowboy's Avatar
please start a new thread, it keeps things clear and grabs more attention for your post
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 06-04-2011, 03:28 AM   #14
Originally Posted by Speedy Petey View Post
Well, did you find anything?
SubStandard Roofing Installation Fred213 Roofing 11 05-06-2008 01:15 AM
Pedestal sink - alternative to anchoring to concrete floor? aktheda Plumbing 2 03-19-2008 02:12 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing 32 02-15-2008 03:10 PM
Installing Pedestal Sink on unlevel floor Manuel6 Plumbing 4 08-09-2007 10:31 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
