-   -   Supplemental RV Pedestal Installation (http://www.diychatroom.com/f18/supplemental-rv-pedestal-installation-21454/)
Helitac 05-26-2008 03:34 AM
This project consists of digging a 24" trench to lay down the direct bury power supply from our existing home meter and the installation of a RV power pedestal (50/30/20 amp). Purpose for the single pedestal is for company with 5-wheel/motor home.
We are planning on using a 4-wire flexible mobile home feeder wire suitable for direct burial w/ sweeps at both ends.
Questions:
What size feeder wire should we use?
With current prices, should we use copper or aluminum?
We live in lightning country, does the pedestal require a separate grounding electrode?
Thank you for any help or suggestions you may make.
Speedy Petey 05-26-2008 06:07 AM
1) Depends on the distance. Under 200' you can go #6CU.
2) If by lightning country you mean the southeast, I'd definitely go with copper. It's a good idea any way.
3) I assume this pedestal has breakers to distribute the load to the different amperage receptacles. You definitely need a ground rod at this remote panel.
Matsukaze 05-26-2008 11:07 AM
Around these parts, a supplementary grounding electrode at the RV pedestal is not required (http://www.cbs.state.or.us/bcd/programs/electrical/2008_electrical_interps/el_interp_RV_Pedestals.pdf), but may be installed if desired. The AHJ in your location may or may not see things the same way. It's probably a good idea to install the supplementary rod at the pedestal if you're in lightning country, even if it's not required.
Speedy Petey 05-26-2008 11:55 AM
If it is a remote sub-panel a grounding electrode IS required.
If it is just an RV receptacle no electrode is required, but a supplementary electrode could be used, not that it would do very much.
From the sound of it, "(50/30/20 amp)", this is a panel, not just a 50A receptacle.
Matsukaze 05-26-2008 04:38 PM
The interpretation I linked to would not apply to the original poster's situation since he is just setting up a space for one RV and not building an RV park. But, if it were a park, all the RV pedestals and the service feeding them would be considered to be a single structure. I have to wonder how many other AHJ's would stretch the definition of "structure" that far.
Helitac 05-27-2008 08:40 PM
We live in the mountains of western Montana which sees a lot of lightning.
Since the single RV pedestal will be located approximtely 150' from the meter, I will be putting in a panel, with a disconnect and individual breakers for 50/30/20 amp circuits.
Any ideas on where someone could pick up a prewired RV pedestal? Local hardware, Lowes and HD aren't familiar with what I need. Otherwise, I'll be back because I will have to make it myself.
This chat is great because it is really helpful in bringing up things one may not have thought of. I appreciate the exchange of ideas. Thanks!
mr500 05-27-2008 08:44 PM
Try
http://www.rvpedestal.com/
http://www.rvpoweroutlet.com/
Go to google type in RC Pedestal and BAMMO:thumbup::thumbup::thumbup::thumbup:
micromind 05-27-2008 10:14 PM
I looked one up in the Square D catalog, it has a 50 amp, a 30 amp, and a 20 amp receptacle in it, along with the associated breakers. It's pedestal mount too.
It's a class 1140, catalog #PAK75G. The 20 amp recpt is GFI protected, if you want the 30 amp one GFI, add 'FI' to the end of the catalog#. This is a 2003 catalog (the current one is in my van, it's raining out, and I'm just too friggin lazy to go get it! lol), the list price is $671. The company I work for usually gets stuff like this for about 1/2-2/3 list.
Rob
Helitac 05-29-2008 01:23 AM
Thank you all for the help! An RV park owner referred me to the person who installed the pedestals in his park. He in turn referred me to a electrical warehouse, where I purchased a pre-wired 50/30/20 amp box.
The wholesaler was willing to sell me the flexible 4-wire but they thought the #6CU was a little light for the distance. I'll chase that down tomorrow.
Appreciate all the help you have provided. Thanks!
Dairygoat 10-17-2009 10:07 AM
I'm doing the same thing as you. I have already got the Pedesta but I still need to get the wire. Does any body know where I can buy the wire around Billings, Montana?
Speedy Petey 10-17-2009 10:51 AM
let me http://www.google.com/intl/en_ALL/images/logo.gif that for you
megronniger 06-03-2011 08:29 PM
I'm looking for instructions for hooking up the earth ground in a milbanks u5240 pedestal installation.
Saturday Cowboy 06-04-2011 02:20 AM
please start a new thread, it keeps things clear and grabs more attention for your post
sirsparksalot 06-04-2011 02:28 AM
Originally Posted by Speedy Petey (Post 341886)
Well, did you find anything? :laughing:
