Super Newbie Question, Help! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 05:33 AM   #16
Code05's Avatar
Rewards Points: 1,104
Originally Posted by Thadius856 View Post
I'm aware that 15A receptacles can be on a 20A breaker in residential. My whole kitchen is wired that way.
I thought I'd read something that said business had to put 20A receptacles on 20A breakers. Is that not accurate?
Originally Posted by jproffer View Post
AHHHH...that could be right . I better yield to someone else for a "for sure" answer on that one.
Sorry about that ...figured you knew...just throwing that in for future readers. Still, with a business I'm not sure.
15 amp receptacles are allowed on 20 amp circuits in commercial also.
This is covered in 210.21(B) NEC.
Code05 is offline   Reply With Quote
Old 01-19-2012, 09:20 AM   #17
Dmx, post it! I'll try to post a picture of my box in the next few days.
cbrown_869 is offline   Reply With Quote
Old 01-22-2012, 01:54 AM   #18
dmxtothemax's Avatar
Rewards Points: 5,512
Heres how it can be done !
It really does work !
The metal mesh is called plasters bead,
Because its a mesh it lets the heat escape,
And with adequate distance between the gel and light it does work !
Dont try it any other way,
it wont work if you do !
it took some experimenting to get it right
if you do it this way it will work !
dmxtothemax is offline   Reply With Quote
NEWBIE QUESTION ALERT!! Jamb Extensions Evil Scotsman General DIY Discussions 24 04-12-2011 05:30 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Newbie w/a flooring question Laminate v. engineered wood UNCgal91 Flooring 2 08-25-2008 07:29 PM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Newbie Question bjp Introductions 2 10-09-2006 02:37 AM
