Super Newbie Question, Help! - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 08:59 PM   #1
Super Newbie Question, help!
Hey guys, I'm building some light boxes for my band to use on stage. Inside the boxes I have two 500 Watt, Utilitech Halogen Work Lights.
Ideally, I'd like to have all four lights running into a surge protector, so that I could turn both boxes on with the flip of one switch.
Is this possible? What type of surge protector/power strip would I need? Will 500 watt bulbs be too bright?
Thank you so much !
-Cody.
cbrown_869 is offline   Reply With Quote
Old 01-18-2012, 09:14 PM   #2
jproffer's Avatar
Rewards Points: 706
What do you mean by "4 lights" ?
If you mean 2 boxes with 2 bulbs each, that would be 2000 watts which is about 17 amps (assuming they are 120 volt), so a 20A breaker would work.
If you mean 4 boxes, with 2 bulbs each, then it would take a 40A breaker, but I doubt you'll find a SP rated for 40A feed.
jproffer is offline   Reply With Quote
Old 01-18-2012, 09:32 PM   #3
Jproffer, I'm sorry, it'd be 2 seperate boxes with 2 bulbs each.
So, something like this would work?
http://www.amazon.com/Tripp-Lite-RS-...6943927&sr=1-1
Thanks again for your help!
Old 01-18-2012, 09:34 PM   #4
Thadius856's Avatar
Rewards Points: 504
Four 500 watt Halogen bulbs is going to put out a massive amount of heat.
Be sure that you're able to safely house that amount of heat!
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 01-18-2012, 09:36 PM   #5
Thadius, thank you! I'll make sure I have plenty of ventilation to the lights!
Old 01-18-2012, 09:50 PM   #6
jproffer's Avatar
Rewards Points: 706
The surge protector you linked is rated for 20A, so it should be fine for 4-500W lights. Make sure it's plugged into a receptacle that's protected by a 20A breaker or they will only run for........(you thought I memorized the trip curve didn't ya, LOL) well I didn't and I don't know how long, but not forever
Old 01-18-2012, 09:55 PM   #7
Haha, excellent. Thank you, again! I hope these places know what their breakers can handle!
Old 01-18-2012, 09:58 PM   #8
Thadius856's Avatar
Rewards Points: 504
Should be straightforward. I'm pretty sure you can tell a 20A receptacle by looking at it.
As far as I know, 20A-rated plugs always have one of the prongs turned 90 from what you'd expect to see. Thus, 20A-rated receptacles should have one regular and one T-shape prong to accommodate either a (standard) 15A plug or a 20A plug.
Old 01-18-2012, 10:07 PM   #9
If you would like to learn a few things and be sure your light box is safe, be sure to post pictures of it here as you work on it, make wiring connections, etc.
There is a lot of knowledge and experience around here!
Billy_Bob is offline   Reply With Quote
Old 01-18-2012, 10:22 PM   #10
dmxtothemax's Avatar
Rewards Points: 5,152
Thank you so much !
-Cody.
The main problem will be HEAT,
These 500w tungsten halogen flood lights produce a LOT of heat,
There will need to be a LOT of air flow !
Or forced cooling (fans).
And gels wont last too long either.
If you go for smaller lamps like 300w,
There will less problems.
But air flow will still be needed !
dmxtothemax is offline   Reply With Quote
Old 01-18-2012, 10:29 PM   #11
jproffer's Avatar
Rewards Points: 706
What you say is true, but just because the rec. is 15A rated doesn't mean it is certainly on a 15A breaker. 15A rec's are allowed on 20A breakers as long as there are at least 2 rec's on the circuit.
Old 01-18-2012, 10:36 PM   #12
Thadius856's Avatar
Rewards Points: 504
I'm aware that 15A receptacles can be on a 20A breaker in residential. My whole kitchen is wired that way.
I thought I'd read something that said business had to put 20A receptacles on 20A breakers. Is that not accurate?
Old 01-18-2012, 10:39 PM   #13
jproffer's Avatar
Rewards Points: 706
AHHHH...that could be right . I better yield to someone else for a "for sure" answer on that one.
Sorry about that ...figured you knew...just throwing that in for future readers. Still, with a business I'm not sure.
Old 01-18-2012, 11:37 PM   #14
Haha, all of this is over my head. I'm going to make the switch to 250 watt lights to avoid the heat issue and cut down on amp load. Thank y'all for everything!
Old 01-19-2012, 04:42 AM   #15
After much experimenting I did find a way to use these
type of cheap flood lights for color washs.
I use 500w ones,
because they are cheap and redily available,
if you like I will try to get a photo of how I did it !
And post it on line early next week .
NEWBIE QUESTION ALERT!! Jamb Extensions Evil Scotsman General DIY Discussions 24 04-12-2011 05:30 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Newbie w/a flooring question Laminate v. engineered wood UNCgal91 Flooring 2 08-25-2008 07:29 PM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Newbie Question bjp Introductions 2 10-09-2006 02:37 AM
