Suntouch Electric Radiant Floor Heating Reg - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2009, 04:49 AM   #1
Suntouch electric radiant floor heating reg
I'm Planning to install suntouch electric raidant floor heat this
winter, But I've heard of some electric radiant products burning out
prematurely. How is SunTouch better than others?
Jim Anderson is offline   Reply With Quote
Old 10-24-2009, 07:27 PM   #2
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
Suntouch is a line voltage radiant system. You'll get MUCH more life out of a low voltage system. Low voltage elements come with a 25 year element warranty. Most line voltage systems only have a 10 year warranty...for a reason.
The problem with most systems is either they are installed incorrectly or someone damages the element on install.
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Old 10-24-2009, 08:21 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,928
I notice you're a vendor of low voltage floor heating systems. I have to call BS on this claim. For the same wattage density per square foot (same heating performance) the elements will operate at the same power density per linear foot, and thus the same temperature. The only difference is that a low-voltage system runs at much higher current, and has an extra device (transformer) to buy, and possibly to fail. There is no basis to believe that a low voltage system of equal performance will last any longer.
The one advantage I can see for low voltage is safety, and that may be a significant advantage. Line-voltage systems rely on concentric conductors and ground fault protection to prevent a shock hazard in case of failure. With a low-voltage system there is simply no hazard to begin with.
Yes, and that problem occurs with both line and low voltage systems.
mpoulton is offline   Reply With Quote
Old 10-25-2009, 08:13 AM   #4
Rewards Points: 150
First, we sell BOTH line and low voltage. Yes, of course, you lower the volts, you raise the amps. That's a given. Given the same wattage psf, naturally they will perform /cost the same.
The low voltage element is completely different than a line voltage element. If line voltage elements last as long as low, why the 10 year warranty?
There are many other advantages to low over line. Do more homework on it and you'll see.
That's why I said "most"...you're assuming I was speaking only to line voltage installation.
Electric Radiant heat on Concrete hayduke.klr07 Electrical 10 11-24-2008 07:31 PM
Electric radiant Joe F HVAC 9 06-16-2008 03:17 PM
Advice - Electric Radiant Floor ! sandy2982 Flooring 2 04-15-2008 02:07 AM
porcelain tile over electric radiant heat aak3 Flooring 7 01-30-2008 08:33 AM
Electric radiant heat in the garage art2670 Flooring 4 01-26-2008 08:58 AM
