Sunken Outlet - Electrical - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By J. V.
  • 1 Post By darren
Old 01-28-2008, 01:51 PM   #1
Rewards Points: 101
Sunken Outlet
I have been replacing all the outlet/switch plates after painting a house I recently purchased. Some of the outlets are set a bit too deep in the wall. The screws from the cover plate will not reach. Is there anything that I can do to bring to outlet outward a bit more? Something like the idea of washers to raise it up?
jte1130 is offline   Reply With Quote
Old 01-28-2008, 03:44 PM   #2
Rewards Points: 6,652
You have to get shims made specifically for moving the outlet forward. Also, longer screws are usually available in most shim kits that can be purchased from any local Home Improvement store. If not, purchase standard machine thread screws from the fastner section. There is a thread measurer available in those aisle for consumers to use to check the thread and size of screw.
Old 01-28-2008, 04:26 PM   #3
Electrician
Rewards Points: 800
Take some wire(the black or white in a piece of lomex will do fine. Wrap it around your screwdriver a bunch of times. Cut it to the thickness you need put it behind the switch put your screw in and it will hold the switch out to where you need it.
Hope this makes sense.
darren is offline   Reply With Quote
Old 01-28-2008, 04:30 PM   #4
I've seen washers, larger nuts, #8 wire insulation, and very small gauge wire wrapped around the screws.
No matter WHAT method you use, install a NYLON coverplate. You can tighten them down snug and they won't crack.
220/221 is offline   Reply With Quote
Old 01-28-2008, 08:11 PM   #5
Union Electrician
goose134's Avatar
Receptacles and switches are held in with 6/32 screws. A good way to shim the outlets (IMHO) is to run the screws through 1/4x20 nuts. Put the nuts behind the receptacle yoke, run the screw through them and tighten. I've never had to do this in a plastic box, but I cannot imagine why it would be that much different.
goose134 is offline   Reply With Quote
Old 01-28-2008, 09:54 PM   #6
Neanderthal Woodworker
woodman51jfk's Avatar
.........do they still allow the use of extension rings?
woodman51jfk is offline   Reply With Quote
Old 01-28-2008, 11:56 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yes woodman they do and this would be the cats meow in most cases. If the recess is 1/4" or so an extension ring works well. Where it becomes more difficult is when the recess is just barely keeping the cover plate screw from reaching the receptacle and the hole is cut too large for the ears of the receptacle to rest on the drywall or finish surface and have the box to support it. If the ears will lay on the finish surface then a box extender works well. Extension rings will work but the recess must be enough for the standard sizes . Carlon makes an adjustable one and a new product for 1/4" or deeper recess has recently been on the market and works well. Without a picture of the problem it is hard to say which works the best. anyway here is an extension ring that works well in some cases. Go to the carlon website to view their choices and I have an image attached for one of them. There are many types so you have to look around to see what best works for you.
http://www.receptxtenders.com/products.htm
Carlon extender
Old 01-29-2008, 08:33 AM   #8
Rewards Points: 101
Thanks, all good suggestions. The more I read these forums the more I am learning there are alot of simple fixes out there.
Old 01-29-2008, 08:36 AM   #9
........thanks Stubbie...........just was wondering if that might work for jt, since I've seen quite a few times where the drywallers buried boxes in new construction............I know hard to believe...but it has happened
Old 01-29-2008, 06:34 PM   #10
I always use the boxes that you can adjust in or out, due to you never know what is going to happen during the install of the Gypsum or mudding. Also makes for easier cutting of the Gypsum board, due to you can retract the box back for the pre-install.
Old 05-12-2017, 10:56 AM   #11
Rewards Points: 2
Re: Sunken Outlet
Look on Amazon for Effortless Electrical Spacers. They work great for this problem.
bob d is offline   Reply With Quote
Old 05-12-2017, 11:50 AM   #12
Rewards Points: 204
Re: Sunken Outlet
This thread is 9 years old man.
Oso954 likes this.
If it worked before you worked on it. You did something wrong.
Old 05-13-2017, 08:15 AM   #13
Electrician
Rewards Points: 800
Re: Sunken Outlet
Maybe the OP still as not corrected the problem.
On another note, how do people find these threads that are 9 years old. I have trouble finding a thread I commented on 3 weeks ago.
jbfan likes this.
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
Electrical outlet hook up. helpless handyman Electrical 4 07-30-2007 08:18 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 10:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 04:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
