Old 04-28-2008, 02:13 PM   #1
JHill's Avatar
"sunk-in" receptacles
Hi all. Looking for some direction here.
Putting the final touches on a finished basement. Went to put the outlet covers on today and there is a little gap from the front of the outlet to the cover. Looks as if the receptacles themselves are sunk in a little too deep (maybe 1/8 of an inch).
Any suggestions on how to correct this without having to tear down walls and readjust the boxes?
JHill is offline   Reply With Quote
Old 04-28-2008, 02:19 PM   #2
Moderator
Termite's Avatar
Longer screws on the receptacles, switches, and cover plates will take care of most circumstances.
If the box is mounted too deep in plywood or another combustible material, a plastic box extension (spark ring) would be necessitated. You can't have combustible materials exposed to the inside of the box. They're very inexpensive and are available from most electrical supply stores (My local Lowes and Home Depot don't have them). Allied Moulded is one manufacturer that comes to mind.
Old 04-28-2008, 02:39 PM   #3
JHill's Avatar
Thank you for the reply.
Forgive my ignorance but I can't see how longer screws would work. If the receptacle in not firm against the box itself, wouldn't the outlet move?
Old 04-28-2008, 03:00 PM   #4
Underground Techie
sevver's Avatar
Oulets have drywall ears that should hit the dry wall. But a good solid solution would be to use washers on the back side of the outlet on the screw to even it out.
sevver is offline   Reply With Quote
Old 04-28-2008, 03:04 PM   #5
J Calvin Construction
jcalvin's Avatar
The longer screws will be needed to pull the outlet out of the box some more. I like to have my outlets tight against the wall and I generally lean toward getting unbreakable covers and cranking them down.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 04-28-2008, 05:47 PM   #6
When is fishing season?
CowboyAndy's Avatar
You need to use a box extender. If the recep is set back, then chances are the box is set back too, and there can be no more than 1/4" of exposed sheetrock.
Also, if you just put in longer screws, then the outlet cover will break (if it is hard plastic) when you push a plug into it, or flex slot (if it is a nylon unbreakable cover).
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 04-28-2008, 06:43 PM   #7
JHill's Avatar
Thanks for all the great tips!!
I went over to an electrical supplier in town and they directed me so the "spacers" that go behind the receptacles to bring them forward. I had no idea that these things even existed.
Thanks again everyone...... another problem solved thanks to these boards!
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
GFCI Receptacles dankreboot Electrical 7 04-09-2008 11:53 AM
gfci receptacles rjr Electrical 2 05-02-2007 08:16 PM
4-way circuit with 9 duplex receptacles crecore Electrical 7 09-01-2006 10:39 PM
Number of receptacles and size of wires KUIPORNG Electrical 5 06-28-2006 02:21 PM
