Sump Pump Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2010, 02:37 PM   #1
Just call me Andrew
Rewards Points: 1,020
Sump pump wiring
I was at a friends' house who is in the process of finishing his basement. His sump is GFCI protected, and that circuit also feeds a couple of downstream receptacles.
1. I know GFCI on a sump outlet is an area of controversy....latest thoughts there?
2. Does the sump need it's own dedicated circuit?
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 03-05-2010, 04:35 PM   #2
Civil Engineer
Rewards Points: 4,568
I always put a sump pump on its own circuit, you don't want the pump breaker to trip because you overloaded the circuit with some other appliance. As to GFI, it is in the basement, so code requires GFI if I am not mistaken. The only issue is that GFI outlets are twitchier about tripping in the event of a fault, and you may not like to take the risk that the pump goes dead in the middle of a rain event because the GFI goes off. Assuming it is code, as I think it is, to use GFI outlets in the basement, the only code compliant answer is to install a GFI and live with the risk that it trips.
Old 03-05-2010, 09:01 PM   #3
What Daniel said, and be sure you add the rider to your homeowners insurance policy that covers water damage. Many policies don't.
houseinthewoods is offline   Reply With Quote
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Quick HVAC / sump pump wiring question MattOverMinder Electrical 4 01-23-2009 08:42 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
Sump Pump wiring Redline77 Electrical 2 09-25-2007 10:16 AM
