Sump Pump Trips GCFI - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2012, 04:36 PM   #1
sump pump trips GCFI
I have an outdoor sump pump that trips the GFCI circuit I have it on. Out of the water the circuit and components work well. I have read forums to learn that a class B 30mA GFCI could alleviate the problem.
drew7ster is offline   Reply With Quote
Old 08-10-2012, 04:42 PM   #2
Rewards Points: 13,446
Or the GFI is bad or damp.
Post a picture of how you have it pluged in.
It needs a cover over the outlet box that's made so the cover can be fully closed and still have the GFI plugged in.
Something like this.
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
PaliBob (08-11-2012)
Old 08-10-2012, 04:51 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,922
Does it trip only when the pump turns on? If it trips immediately on plugging in, even before the pump turns on, then it's probably the switch rather than the pump. If it only trips when the pump comes on, then it's more likely to be the pump. Are the switch and pump separate, with the pump plugged into the switch? If so, try plugging the pump into the receptacle without the switch and see if it trips. Also try plugging the switch in with some other load (like a lamp or something) to see if it still trips.
Chances are it's the pump. Sometimes they aren't properly sealed and leak a bit of water inside, causing a ground fault. Be careful while testing - there's almost certainly a real ground fault and it's a dangerous condition to mess around with.
mpoulton is offline   Reply With Quote
Old 08-11-2012, 06:18 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by drew7ster View Post
.....I have read forums to learn that a class B 30mA GFCI could alleviate the problem.
Drew welcome to the forum. There is such a 30mA device designed for equipment only protection. Whether or not such a device would be legal in your location would depend on your local Authority. Here is some background.
To help with GFCI issues I made my own GFCI margin Tester
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-11-2012, 07:39 AM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Buy a new sump pump, it's defective... easy as pie.
Old 08-11-2012, 07:48 AM   #6
E2 Electrician
Not going to happen... You need a class A device to meet code.
Old 08-11-2012, 08:43 AM   #7
Is this something that just started happening after it has been working for awhile?
If so, you probably need a new sump pump. Most likely a seal is defective.
It's possible your GFI has gone bad. A new GFI is around $10.00. It's a cheap attempt at trying to solve your issue before going to purchase a new sump pump.
parman is offline   Reply With Quote
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 01:17 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
sump pump "pit falls" bubbler Plumbing 6 03-09-2011 08:45 AM
sump pump water lower than normal???? fabian Building & Construction 18 12-05-2009 05:26 AM
On Off Indicator For Outside Sump Pump Lawrence Coppar Electrical 31 03-29-2009 01:01 PM
