Sump Pump Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 02:10 PM   #1
Rewards Points: 512
What does the Code say about these?
Does it have to be GFCI protected?
What about when using a single receptacle?
Dedicated Circuit? (plumbers are going to plug it ito my washing machine circuit)
tks.
Old 03-11-2011, 02:13 PM   #2
Licensed electrician
Rewards Points: 1,870
Under the 08 NEC the receptacle for the sump pump would require GFI protection if it is in a crawlspace or an unfinished basement. The exemption for a single receptacle has been removed.
Old 03-11-2011, 03:01 PM   #3
Civil Engineer
Rewards Points: 4,938
I realize that a sump pump outlet under the NEC is treated like any other outlet in the basement, hence is required to be GFI, however consider that the GFI may trip for a variety of reasons, including moisture in the GFI, which would be very unfortunate if the pump shut off during a flood. This is a case where you may be better off with a dedicated circuit not on a GFI, much as mission critical circuits in hospitals are not always GFI, as I understand it. As this is a technical code violation, I cannot recommend this approach, but it is worth considering.
Old 03-11-2011, 04:15 PM   #4
Rewards Points: 512
Thanks for the replies, guys.
Our county is on the 2005 Code, so I'm thinking that a single receptacle, dedicated non-GFCI would be okay. ??
Old 03-12-2011, 08:05 AM   #5
Electrician
SD515's Avatar
Rewards Points: 504
In Michigan we're still on the '05 code for single & 2 family dwellings, and that's what we do.
Kyle
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Sump Pump french drainage issue HomeDIYslfr Plumbing 1 05-16-2009 12:21 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
