Sump Pump On Its Own Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2012, 02:22 PM   #1
Do it yourselfer
sump pump on its own circuit
My sister recently bought a new house and the inspector suggested putting the sump pump on its own circuit and not be on a GFI to make sure that it wont trip. My question is should the sump pump be on a 20 amp circuit or a 15 amp circuit? And if it should be a 20 amp circuit with 12-2 can I still use a 15 amp duplex outlet.
mjklein67 is offline   Reply With Quote
Old 02-20-2012, 02:29 PM   #2
Should be on its own circuit. 15 A circuit is more than enough. And if you do run 12/2 and put in a 15 A receptacle, just make sure the breaker is also a 15 A.
hawkeye11 is offline   Reply With Quote
Old 02-20-2012, 02:35 PM   #3
Do it yourselfer
My first thoughts were to installed a 15 amp breaker with 14-2 and a 15 amp outlet. Is this enough or not?
Old 02-20-2012, 02:40 PM   #4
Yes, that's sufficient to handle the sump pump.
The Following User Says Thank You to hawkeye11 For This Useful Post:
mjklein67 (02-20-2012)
Old 02-20-2012, 02:55 PM   #5
Rewards Points: 1,520
Just to stir the pot, it is my recollection that current code requires GFCI for sump pumps. Makes sense in one way and not in another. Might want to check which code cycle your home is covered by.
bob22 is offline   Reply With Quote
Old 02-20-2012, 09:19 PM   #6
Julius793's Avatar
Not true it can be on a 20 breaker it it's a duplex outlet.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-20-2012, 09:19 PM   #7
Julius793's Avatar
I don't think so
Old 02-20-2012, 09:23 PM   #8
In Canada, a sump pump receptacle is not required to be GFI protected.
Old 02-20-2012, 09:33 PM   #9
Rewards Points: 109
Yep that's correct.
Daltex is offline   Reply With Quote
Old 02-20-2012, 09:38 PM   #10
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
You can use a 15a recept on a 20a circuit
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-20-2012, 09:45 PM   #11
Rewards Points: 734
2008 NEC removed the exemption so sump pumps are to be GFCI protected.
AandPDan is online now   Reply With Quote
Old 02-20-2012, 09:52 PM   #12
...yeah, sorry ppl, I totally read that wrong. Yes, you can use a 15A receptacle on a 20 A circuit...my bad. And again, the CEC does not require a permanently installed sump pump to be GFCI protected.
Old 02-20-2012, 11:07 PM   #13
Code05's Avatar
Rewards Points: 1,104
If it was hard wired - no cord - neither would the US.
It is the 120v receptacle, not the pump that requires GFCI.
Code05 is offline   Reply With Quote
Old 02-21-2012, 03:24 AM   #14
" Euro " electrician
frenchelectrican's Avatar
Just be aware that some of the states which they did adopted the 2008 and later NEC codes they still modifed the codes and I know in State of Wisconsin still have extempt for sump pump only if singleplex power point ( receptale ) if duplex then no it have to be GFCI'ed.
Ditto with the furance ( for gaz ou oil fired units )
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
NJMarine (02-21-2012)
Old 02-21-2012, 06:51 AM   #15
Rewards Points: 1,418
.... Yes, you can use a 15A receptacle on a 20 A circuit. ...
Okay with a mininum of two single receptacles or one duplex on the circuit altogether.
Sump Pump questions ks-man Plumbing 11 07-28-2011 07:25 AM
Sump pump runs all the time....help? Chris Leach General DIY Discussions 9 07-14-2011 08:00 PM
Sump Pump Hole Wet but no Sump Pump judylong1 General DIY Discussions 4 06-03-2011 10:08 AM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 11:51 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
