Old 07-08-2011, 01:51 PM   #1
cuz
sump pump circuit
I have an outside lamp post with 400 watt capacity that is wired to the sump pump that is on a GFI in a Bathroom. Keeps tripping. Is it Code that Sump Puump has to be on seperate circuit??
cuz
cuz is offline   Reply With Quote
Old 07-08-2011, 02:01 PM   #2
Master Electrician
sump pump circuit
Light and sump should not be on bathroom circuit.
brric is offline   Reply With Quote
Old 07-08-2011, 06:43 PM   #3
Semi-Pro Electro-Geek
sump pump circuit
The sump pump should be on a dedicated circuit. It does not have to be GFCI by code, but should be in my opinion - submersible pumps do frequently have ground faults, and it can be very dangerous. The yard light should also not be on the bathroom circuit, but can share a circuit with something else. GFCI protection for it is also a good idea, and may be required depending on how it's wired. You'll find out when you separate them which thing is causing the existing GFCI to trip.
mpoulton is offline   Reply With Quote
Old 07-08-2011, 09:43 PM   #4
Licensed electrician
sump pump circuit
Article 210.8 in the 2011 has been revised and would now require GFI protection for the sump pump unless it was 240 volt.
frenchelectrican (07-08-2011)
Old 07-08-2011, 10:52 PM   #5
" Euro " electrician
frenchelectrican's Avatar
sump pump circuit
Jim ., Just be aware some local codes may try to override the new code edition. I know state of Wisconsin say if duplex then oui RCD { GFCI } but singleplex some area say GFCI and some say no GFCI but in France we allready have RCD protection and genrally it will be it own circuit.
Merci,
Marc
Tags
electrical code, plumbing codes
Sump pump runs all the time....help? Chris Leach General Discussion 9 07-14-2011 08:00 PM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 11:51 AM
Sump Pump / Outdoor drainage HELP! Shamrexm Plumbing 0 06-15-2010 06:52 PM
Sump pump running often for first time ever benezet Plumbing 37 04-16-2010 07:53 PM
Water Mystery - Sump Pump Set Right? robertr4836 General Discussion 4 02-13-2008 03:32 PM
