Summer Vacation - Main Off? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2012, 07:32 PM   #1
Rewards Points: 119
Summer vacation - Main off?
Hi all,
this summer I will be away for one month, is there anything against switching the main breaker circuit off?
Anything I should pay particular attention too?
My neighbor will come and see if everything is fine on a regular basis.
Alex
Metallo is offline   Reply With Quote
Old 05-20-2012, 08:06 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Sump pump?
Old 05-20-2012, 08:13 PM   #3
Rewards Points: 40
Timed lights and radio on for that lived in look? Do you have an alarm system?
daveb1 is offline   Reply With Quote
Old 05-20-2012, 08:53 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
If the main breaker is red, do NOT turn it off. You'll likely not be able to turn it back on again.
Old 05-20-2012, 09:22 PM   #5
Rewards Points: 119
No sump pump, no alarm system and the breaker is black, it is an ordinary panel.
What's a red breaker for?
Alex
Old 05-20-2012, 09:28 PM   #6
vln
Underwriter
FPE (Federal Pacific Electric panel)
vln is offline   Reply With Quote
Old 05-21-2012, 12:47 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Also Pushmatic Main breaker which I get them from time to time they will not able latch back on postion so that is the other type of breaker ya have to watch out ( only major qurik is they not in production for many years so may end up replace the panel { the main breaker will cost more than the modern panel will be })
Merci,
Marc
Old 05-21-2012, 07:24 AM   #8
Rewards Points: 3,256
Can I ask why you feel the need to shut the power off? What precautions do you take while you are sleeping in this house? I would worry more about a water pipe breaking. Shut off the water main and water heater.
Notice I didn't say hot water heater.
zappa is offline   Reply With Quote
Old 05-21-2012, 04:47 PM   #9
vln
Underwriter
Make sure to have the water heater heat the water to at least 140 degrees before using it again, you may get Legionnaires disease.
Old 05-21-2012, 06:12 PM   #10
Rewards Points: 2,188
What about your freezer and fridge if there's no power?
I used to unplug every single thing in the house and flip the water heater breaker off, to not waste electric if I was gone.
vln: I never thought about Legionnaires Disease! Would you recommend turning the water heater up to 140 even if that's not what you normally set it at? I think I keep mine at 130.
Startingover is offline   Reply With Quote
Old 05-21-2012, 07:04 PM   #11
Rewards Points: 119
Well, simply because in 4 weeks you save between 150 and 200 bucks and I do not want to switch every single appliance off.
Alex
Old 05-21-2012, 07:07 PM   #12
Rewards Points: 119
You are absolutely right, I will remember it before taking a shower.
This is obviously regardless you switch the main or the heater off .
Alex
Old 05-21-2012, 07:08 PM   #13
Rewards Points: 119
Before leaving I always leave them empty, there is no point in keeping them on.
Alex
Old 05-21-2012, 10:19 PM   #14
vln
Underwriter
Yes, I would. It is especially important on electric water heaters. Or in places with extreme climate.
Old 05-21-2012, 10:25 PM   #15
Msradell's Avatar
Rewards Points: 276
Alex
If everything in your home is turned off your little usage is going to be minimal if any at all. You certainly aren't going to use $150-$200 worth of electricity was no one there using anything. I certainly agree with the suggestion to turn off the water but I really wouldn't bother turning off electricity.
Msradell is offline   Reply With Quote
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
main burner goes out after furnace running 10 -2 0 mins marion60 HVAC 4 11-02-2011 09:53 AM
Main Electric Panel Help Redrum Ninja Electrical 13 10-22-2011 07:28 PM
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 08:15 PM
Arced main lug in service panel burgeke Electrical 4 11-02-2006 11:28 AM
