Suffolk County, NY Electric Code Requirement - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 11:01 AM   #1
suffolk county, NY electric code requirement
Hello
I want to add lighting along my driveway (not low voltage) and have about a 80-100 foot run from my source. what type and gauge cable should i use for 125v 20 amp circuit? how deep does it have to be buried and does it have to be in conduit of any type?
thanks
dominick
dmc84dds is offline   Reply With Quote
Old 04-21-2013, 12:20 PM   #2
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by dmc84dds View Post
Hello
thanks
dominick
12/2 gauge UF wire .. 12 inches ... IF it does not cross the driveway IF it does then accross(under) the driveway ... 24" at that location
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 04-21-2013, 12:42 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Actually it's 24"; unless it is under a residential driveway or parking area, then it is 18"; or if it is protected by GFI before it goes underground then it is 12".
NEC T300.5 or NYS Resi Code Table E3703.1
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
k_buz (04-21-2013), Philly Master (04-22-2013)
Old 04-21-2013, 04:32 PM   #4
Rewards Points: 516
actually it is 12" the whole way ..... 2011
Column 4
Residential Branch Circuits Rated 120 Volts or Less with GFCI Protection and Maximum Overcurrent Protection of 20 Amperes
and
One- and two-family dwelling driveways and outdoor parking areas, and used only for dwelling-related purposes
Note :
4. Where one of the wiring method types listed in Columns 1–3 is used for one of the circuit types in Columns 4 and 5, the shallowest depth of burial shall be permitted.
PHP Code:
http://code.necplus.org/sample/document.php?id=necss%3A70-2011%3Anecs70-300.5
Old 04-21-2013, 04:48 PM   #5
Rewards Points: 13,950
Why not just solor lights? No digging, no wiring.
Old 04-21-2013, 04:51 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
yeah... no.... lol...
Old 04-21-2013, 05:38 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Column 4
and
Note :
4. Where one of the wiring method types listed in Columns 13 is used for one of the circuit types in Columns 4 and 5, the shallowest depth of burial shall be permitted.
PHP Code:
That is just reinforcing Speedy's point that in order to use the 12" for UF cable, it would need to be GFI protected.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
Philly Master (04-22-2013), stickboy1375 (04-21-2013)
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
Electric Oven power requirement Whaler Man Electrical 2 01-03-2013 11:56 AM
National Electric Code for Bathrooms mehaley Electrical 15 07-23-2008 09:55 AM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 02:57 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 10:06 AM
