Sufficient Box Volume In 2x3 Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 10:09 PM   #1
Sufficient box volume in 2x3 wall
Hi,
I need to install an outlet in an existing 2x3 wall but can't figure out how to get enough box volume in this skinny wall. The studs are 2 5/8" with 7/8" of gypsum lath and plaster. I need 20.25 in3 of box volume to handle the 12/3 in and out and the device.
4x4 box with mud ring would give the volume, but how to set in as old work box with a single gang outlet? Using old work wings would bring the box flush with wall, but then faceplate won't cover if only trying to install one device.
Ganging together two single-gang old work boxes has the same problem of having a double gang exposed when I only need one.
The only thing I've come up with so far was to gang together two old work boxes, setting them behind the plaster, one covered with a faceplate, and the other with a box extender to bring it through the plaster.
beffreyj3 is offline   Reply With Quote
Old 11-17-2011, 10:17 PM   #2
Sparky
Rewards Points: 510
why are you using 12/3? do you need 2 circuits?
Techy is offline   Reply With Quote
Old 11-18-2011, 07:34 AM   #3
Licensed electrician
Rewards Points: 1,240
Try one of these with a ring.
http://www.aifittings.com/catalog/fa...-boxes/fsr404s
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 07:17 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
