Old 07-02-2009, 04:35 PM   #1
Subwoofer picking up noise/signal when ceiling fan is switched on
I recently connected ceiling fan with light kit in our living room which also has entertainment center, amplifier and subwoofer.
When the subwoofer is on and if we switch on/off the fan, subwoofer picks up the signal from the fan switch and makes noise (like thud). Is there any problem with the wiring or fan or it electro-magnetic thing going on here? This noise doesn't persist, sound comes from the subwoofer when the fan switch is in the middle i.e. neither on/off.
johnharold22 is offline   Reply With Quote
Old 07-02-2009, 05:42 PM   #2
Experienced goon
Probably not a wiring problem per se... Are the two on the same breaker (ie, is there one breaker in the basement that when powered off, turns off both the sub and the fan?). You might plugging the sub into a line-conditioner or UPS to avoid the pop, or switch to another outlet.
jpelzer is offline   Reply With Quote
Old 07-02-2009, 06:23 PM   #3
It was a dark and stormy
Yoyizit's Avatar
High current demanded on fan startup temporarily drops the line voltage to your amp?
Try running your amp from a different CB using a heavy extension cord.
It could also be a bad connection in your house wiring that only shows up under heavy current draw. A 10A hair dryer plugged into this outlet should drop the voltage about 3v, depending on several factors.
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Adding Ceiling Light From Switched Outlet vboz5 General Discussion 2 03-04-2009 01:53 PM
Replace Switched Receptical with Ceiling Fan chuckroc76 Electrical 1 07-12-2008 04:45 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Turning Switched Outlet Into Ceiling Fixture 39centstamp Electrical 10 06-08-2007 01:07 PM
