Subpanels And Not Bonding The Ground Bar - Electrical - DIY Chatroom Home Improvement Forum
Old 02-06-2013, 11:39 PM   #1
Rewards Points: 330
subpanels and not bonding the ground bar
If you separate the neutrals from the grounds what happens if
the bare ground wire touches the back of the panel?
Or is the neutral bar that you remove the bonding screw from
to separate from the panel?
kt82 is offline   Reply With Quote
Old 02-06-2013, 11:55 PM   #2
Engineer
Rewards Points: 161
The back of the panel will be tied to the ground (so entire cabinet is grounded.) The neutral bar is what is completely isolated from ground in a sub.
diystephen is offline   Reply With Quote
The Following User Says Thank You to diystephen For This Useful Post:
kt82 (02-07-2013)
Old 02-07-2013, 12:19 AM   #3
Rewards Points: 330
thanks makes sense .if I have #2 feeder wire my ground wire is___?
Old 02-07-2013, 12:26 AM   #4
Rewards Points: 330
Are you asking how to size the;
Equipment Grounding Conductor? 250.122
Grounding Electrode Conductor? 250.66
Grounded Conductor (the neutral) 220.61
In what way is the "neutral" considered a grounded conductor?
Old 02-07-2013, 07:01 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Are you answering your own questions?
Old 02-07-2013, 08:14 AM   #6
Licensed electrician
Rewards Points: 1,296
I think they are looking to see if they would be using the correct article to size the conductors. They seem to have found an answer, but want someone to say whether it is correct.
Old 02-07-2013, 08:40 AM   #7
Rewards Points: 330
just thinking out loud so I can frame my question
Is #6 the correct ground with #2 feeding the subpanel
