Subpanel Wire Size Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 12:17 PM   #1
subpanel wire size question
I've installed a 125 amp Siemens main lug as a subpanel next to my main in the basement, I plan on powering it with a 60amp breaker from the main. I've read that 6/3 nm-b with ground can be used, so as a I was starting to hook everything up I happend to glance at the label on the panel and it says to use 2/0-4awg. Is the 6/3 too small or can I go ahead and use it? Thanks
bmludwig is offline   Reply With Quote
Old 11-28-2012, 01:40 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Smallest wire the lugs are rated for is #4. Can't use #6.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 11-28-2012, 01:49 PM   #3
Licensed electrician
Rewards Points: 1,598
You could splice on a short length of #4 to the #6 and fit the #4 in the lugs.
Old 11-28-2012, 02:01 PM   #4
joed's Avatar
Rewards Points: 12,850
Or you could change the lugs to ones that will fit your wire.
Old 11-28-2012, 03:00 PM   #5
I didn't know chaning out the lugs was allowed? I see some on the home depot site that may fit my box.
Don't really want to splice the wire.
Or I suppose I could go get some #4thhn and run it in some conduit. not at home to look at the breaker but I think #4 will fit in a 60amp
Old 11-28-2012, 07:05 PM   #6
Just use the lugs and forget about it.
Macken is offline   Reply With Quote
Old 11-28-2012, 07:23 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
We try not to endorse hacking at a DIY site...
The Following User Says Thank You to stickboy1375 For This Useful Post:
electures (11-28-2012)
Quick Wire Size Question leeave96 Electrical 5 08-22-2011 05:33 PM
wire size vs breaker size Jimster 481 Electrical 3 08-20-2011 09:41 AM
wire size for 160' feeder to subpanel steveski Electrical 3 05-21-2011 09:41 AM
Yet another subpanel wiring question Chris_M Electrical 6 06-10-2010 05:12 PM
Important Wire Nut and Electrical Tape Question Wolfies167 Electrical 22 01-06-2010 12:59 PM
