Old 05-15-2011, 02:17 PM   #1
E-lec-tri-city
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
Subpanel - where to start?
Is there a sticky or an FAQ on this?
I need about 3-4 more circuits than my main box has capacity for. Main box is a 125 amp service with capacity for 24 breakers and it's a SquareD. I want to install a subpanel upstairs.
How many amp subpanel do I need?
What kind of wiring between the main box and the subpanel?
What kind of breaker do I put in the main box to feed the subpanel?
Do I need conduit between the main box and the subpanel?
What kind of wall do I need to install it on?
(thinking the master bedroom closet).
What kind of circuits should I put on it, I was thinking just lights and plugs and leave the heavy draws in the main box?
Thanks in advance for any info you have.
brons2 is offline   Reply With Quote
Old 05-15-2011, 03:11 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
That depends on your service calc. not likely to exceed 60a
It must be 4wire, grounds and neutrals must remain seperate in a sub panel
60a= #6
eg. 60a
If not in a detached building- you could use romex(MN) cabling, but if you like conduit go ahead
It can't be installed in bathrooms or closets
You can put any thing on it at all, but it does effect your calc
You may not have to install a sub panel if you can use tandems/quads. (space saving breakers $$)
Installing a sub panel is one of our more popular questions. It is sorta covered in one of the stickies but not directly. A FAQ might be a good idea, with code references.
To start thinking about a sub panel, you need to decide what will be in it. This will determine how big it need to be, as well as a lot of other factors.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-15-2011, 04:18 PM   #3
AN FAQ on Code related questions would be AWESOME
Old 05-15-2011, 07:57 PM   #4
A often used location for a subpanel in a bedroom is behind an entry or other door that typically stands open.
Old 05-15-2011, 11:44 PM   #5
E-lec-tri-city
What do you mean by "your service calc"
60a= #6
eg. 60a
So for a 60 amp subpanel I need to run a 6-3?
If conduit is not necessary, I'd prefer not to. It's not in a detached building.
How about the garage?
What calc?
My 125 amp main panel does not take tandem breakers. It's a SquareD Homeline. The tandem breakers fit fine on the 200A SquareD Homeline main panels but not on mine. I tried it in a big box store just to see.
plugs, lights. nothing major. All the high draw stuff will go back to the main panel.
Old 05-16-2011, 03:49 AM   #6
He's talking about the total power you will be requiring vs. the ampacity you'll need by doing a Load Calculation, which is partially dependant upon the Sqare footage of the house. I think you said you have a 125a Main panel, and you're going to feed a sub with a 60a breaker. Just be sure that you're not exceeding the 125a rating of the Main panel. Here's a link to a load calculator. It's based on the 2002 Code, and there may be (probaby are) some changes. I add it only for your better understanding.
6/3 with ground
Cable is fine then
That's fine. Make sure that it's easily accessible. A minimum (I think) of 36" is required in front of the panel. It has to be easily accessible without having to bend, stoop, or move items around to get to it, and cannot be hidden by a closet door.
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 09:20 PM
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 09:44 PM
Surface Mount subpanel and 110/220 recepts - good idea? vsheetz Electrical 4 11-15-2009 11:29 PM
Subpanel for now, convert to 2nd main panel later? abmiller67 Electrical 2 08-27-2009 02:44 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 10:45 PM
