Subpanel For Washer/dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2008, 01:07 AM   #1
Subpanel for washer/dryer
Hi I would like to know what is required for a new washer dryer to be connected up to my existing electrical system?
wedge22 is offline   Reply With Quote
Old 05-26-2008, 06:10 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Get some wire, breakers, boxes, and receptacles. Install them.
Seriously, your question is WAY too vague to answer. What exactly are you doing?
Your title says sub-panel. What does that mean?
Is this in an unfinished area?
Is this a newer house?
WHAT is your level of skill in this area??????
My gut reaction is to suggest hiring an electrician.
Old 05-26-2008, 09:22 AM   #3
Licensed electrician
Rewards Points: 1,876
Is this a combo washer/dryer or 2 separate machines? Is the dryer gas or electric?
Old 05-26-2008, 03:10 PM   #4
We intend to buy to seperate machines and they will be electric. I have been informed that they have to be on a seperate breaker/circuit in case there is a short as they use alot of power.
Old 05-26-2008, 06:20 PM   #5
The reason they need separate circuits is not because of short circuits. The dryer is a 220 volt 30 amp circuit, the washer is 120 volt 20 amp circuit.
Old 07-27-2008, 03:37 AM   #6
I guess this is something for an electrician to do, I would rather be safe than sorry.
Old 07-27-2008, 10:26 AM   #7
Rewards Points: 240
Don't give up to fast. This is an excellent DIY project IMO.
Do you have easy access from your panel to the washer and dryer area. If so it should be a breeze.
Are you comfortable pulling two cables, mounting two boxes and putting two new breakers in your panel? If the answer is yes, let us know. We will guide you.
Old 07-27-2008, 12:22 PM   #8
Rewards Points: 35
Pulling cable
I have a similar issue. I moved a washer/dryer setup from a dedicated 120v/20a circuit (#3) to another level of my house and am now on a 120v/20a circuit (#8) that serves many outlets and 2 fixtures.
I assume I should run new cable and create a dedicated circuit.
Please explain the DIY process.
TVC15 is offline   Reply With Quote
Old 07-27-2008, 12:53 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You should start a new thread/post so we don't have 2 different things going with this thread.
I am assuming the dryer is gas?
Old 07-27-2008, 04:21 PM   #10
My current panel is downstairs and my new washer dryer will be upstairs so it has to travel through the ceiling. I have no issues with attempting this if its as easy as you make it sound.
Old 07-27-2008, 06:12 PM   #11
You will need to run a wire of the appropriate size and number of conductors from the panel to the new location and install the proper receptacle. Add the correct breaker at the panel.
What voltage and amps does your combo unit need?
Old 07-27-2008, 06:35 PM   #12
UAW SKILLED TRADES
Stubbie's Avatar
Jim
Op says separate dryer and washer.
Old 07-27-2008, 07:13 PM   #13
I have not purchased the new washer and dryer yet but I have been told that almost all of them are 220V in Canada.
Old 07-27-2008, 07:34 PM   #14
ok, a residential dryer will need a 10/3 w/ ground and your washer will need a 12/2 w/ground.....the dryer is 220, the washer is 110.....
LSU_Tigers is offline   Reply With Quote
Old 07-27-2008, 07:35 PM   #15
oh yeah and 30 amp 2 pole breaker for teh dryer and a 20 amp 1 pole breaker for the washer
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
Subpanel question James Con Electrical 1 02-11-2008 10:52 AM
Wiring 100A subpanel nebulous Electrical 9 08-29-2007 02:41 PM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 12:58 PM
