Old 12-07-2006, 12:33 PM   #1
Subpanel questions
My current panels are 60's vintage. Two of them 200 amps each. I believe it's armor clad wiring and I can't buy breakers that fit these anymore. I can find them on EBay though. So two questions:
1. If I bought a big breaker on Ebay can I use it to feed the subpanel?
2. How big of a breaker to feed a subpanel that will feed about 18 circuits covering 2500 sf of living space? 120 Amp good enough?
Or could I just replace one of my panels and feed the power directly to it?
wease is offline   Reply With Quote
Old 12-07-2006, 02:39 PM   #2
Subpanel questions
I think you may as well replace the whole thing with modern panel which use modern breakers... for that... you need to hire someone to do... I believe most code does not allow DIYers to tackle it themselves as the contractor need also to coordinate with the utility company to turn off the main switch..etc...
KUIPORNG is offline   Reply With Quote
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 04:06 AM
subpanel question Brik Electrical 2 11-30-2008 06:31 AM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 01:58 PM
Subpanel over Water JPsAlias Electrical 13 06-05-2007 11:16 PM
