Old 01-16-2007, 03:04 PM   #1
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
subpanel question
Easy question I think. I plan to install a subpanel in my attached garage. My question is about configuration of the panel itself.
Ideally I would like to use a Cutler Hammer CF style panel so breakers are interchangeable with my main. The subpanel does not need a 'main' breaker, of course. What I would like is a main disconnect at the subpanel. A way to turn off the garage/workshop and maybe lock off.
Is there a way to do this with one box? I know I can use a disconnect switch that is in a separate box. Does Cutler Hammer make a CF subpanel with a lockable main disconnect? That would be ideal.
Brik is offline   Reply With Quote
Old 01-16-2007, 11:24 PM   #2
subpanel question
There are locking devices available to lock out a breaker, you can also buy your sub with a lockable door. go to your local electrical supply house they will fix you up.
work union live better.
megawatt is offline   Reply With Quote
Old 11-30-2008, 07:31 AM   #3
elect, contractor
subpanel question
If you want a means to shut of the entire panel then just get one with a main breaker, a main breaker can be used as a disconnecting means wether it is sized for the subservice or larger (your over current protection is in the house panel) to lock it out or lock it inthe off position as the previous post said you can get (order) a panel with a lockable door (though I have not seen that in a residential configuration) I know cutler makes a residential panel with a door I imagine you could install a hasp and padlock it if nessisary, or you can install a locking device on the main, you could infact fabricate your own usinf 2 peices of angle on each side of the main with apropriately placed holes and a long shakle lock, or a hasp set up to close accross the main when in the off possition and padlock it.
ACB Electric is offline   Reply With Quote
More On This Topic
Hi! My name is Chad Smith and I'm a state certified Journeyman Wireman basically a electrician and I'm here today with expertvillage.com. We just installed a new doorbell in this house and after you have picked up all your tools and make sure you have... Read More »
What is Boating Shorepower
What is Boating Shorepower by Expert Village
There are two panels. There's the panel for the battery and the panel for shore power. The twelve volt system, or the battery system, is the one down here. Even while you're plugged into shore power all these items on this panel only run if you have the... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman. Basically, I'm an electrician. I'm here with expertvillage.com today. The first step that you are going to want to take when you are doing anything with electrical work is you are going to... Read More »
Hi! My name is Chad Smith and I'm a state certified Journeyman Wireman basically a electrician and I'm representing expertvillage.com. Today we are installing a new doorbell in our house here. The first step that you should take when you are installing... Read More »
Let's talk about putting a sign on the breaker box to warn others to avoid others turning our breaker back on. You can say something on your sign similar to what I have. Do not turn circuit breaker number 15 on. Bill is installing a dimmer switch in the... Read More »
Basement Renovation Question KUIPORNG Remodeling 235 08-26-2008 10:19 AM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 02:58 PM
Subpanel over Water JPsAlias Electrical 13 06-06-2007 12:16 AM
Can i add a subpanel fed by 10/2 wire? qst4sno Electrical 25 04-25-2007 07:14 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
