Subpanel Question ? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2013, 10:07 PM   #1
Rewards Points: 205
Subpanel Question ?
Hello - I'm adding an 80 AMP sub-panel in my basement and curious as to which manufacturer is the best. I've been advised to use Square D panel and breakers. Does anyone have a preference and/or suggestions? I'm more much more concerned with quality as opposed to price. Thank you.
Jim Ignatowski is offline   Reply With Quote
Old 11-02-2013, 12:13 AM   #2
Rewards Points: 150
Eaton is what I have always used. Siemens is also good too
romex1220 is offline   Reply With Quote
The Following User Says Thank You to romex1220 For This Useful Post:
Handyworker (11-09-2013)
Old 11-02-2013, 07:13 AM   #3
joed's Avatar
Rewards Points: 13,322
I would use the same as the current main panel.
The Following User Says Thank You to joed For This Useful Post:
Know A Little (11-02-2013)
Old 11-02-2013, 07:53 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
People are going to give you all sorts of answers, but I haven't had any problems with any panels or breakers. Now, if you are installing AFCI breakers I would find out which seem to be less problematic and go with that brand panel.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (11-02-2013)
Old 11-09-2013, 11:28 PM   #5
Rewards Points: 205
I've been doing some reading on other forums and I noticed a lot of electricians are recommending Square-D boxes. I think that's the route I'm going. Appreciate the replies.
Old 11-09-2013, 11:32 PM   #6
The guys at home depot recommended Eaton panels to me just because they said there more compatible with most breakers than the other brands they carried.
Handyworker is offline   Reply With Quote
Old 11-09-2013, 11:52 PM   #7
Licensed electrician
Rewards Points: 1,766
Once again the help is giving out poor information. The other brands may fit but that does not mean they can be used in the panel.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
jbfan (11-10-2013), Oso954 (11-10-2013)
Old 11-10-2013, 01:01 AM   #8
you could ask 6 electricians and get 6 different answers....it is really a ford/ chevy thing...and you can mix or match to your main.....I install sq' d and CH all the time and sq d homeline as well....seimans have copper buss's and are high end so is a sq'd QO....FWIW
Bobka is offline   Reply With Quote
Old 11-10-2013, 06:03 AM   #9
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
siemens panels are both ways cooper and alum. //FYI
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
TomMass (11-13-2013)
Old 11-10-2013, 04:00 PM   #10
yep.......for a one timer the install will be a little more of a challenge the selection.....to the op please note there is a certain way a sub panel needs to be wired....note your neutral and ground connections..
The Following User Says Thank You to Bobka For This Useful Post:
Philly Master (11-14-2013)
Old 11-10-2013, 05:24 PM   #11
Rewards Points: 1,016
____________
Vince
Old 11-13-2013, 03:12 PM   #12
+1
Sq D is nice because the breakers are made to take two wires.
TomMass is offline   Reply With Quote
Old 11-14-2013, 09:58 PM   #13
Originally Posted by TomMass View Post
+1
be careful, not all of them can do this. you need to look at the stamping on the breaker to see if it is listed for two conductors on one pole.
itsnotrequired is offline   Reply With Quote
Old 12-15-2013, 09:00 PM   #14
Rewards Points: 150
+1
It had to be listed as a double tap breaker. If you look closely at the screws you should see two little groves in the clamp if its a double tap.
Old 12-15-2013, 09:19 PM   #15
I like Sq D. That's what sparkys put in all the new construction we do. I also have a sq D panel in my house and its easy to find breakers around here for sq D panels than other panels
framer is offline   Reply With Quote
Tags
breakers , panel , square d , subpanel
Subpanel question gerG Electrical 2 07-09-2012 10:44 AM
Yet another subpanel question md2lgyk Electrical 30 07-28-2011 08:19 AM
Yet another subpanel wiring question Chris_M Electrical 6 06-10-2010 05:12 PM
subpanel question Brik Electrical 2 11-30-2008 05:31 AM
Another subpanel question:) primal65 Electrical 15 06-22-2008 09:43 AM
