Subpanel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 09:50 AM   #1
Question
Subpanel question
Hello all, Another newbie here. I had an old 50A hottub circuit that we don't use anymore so I decided to convert it to a subpanel so I could easily add a few 120V outlets we need in our basement and office area.
I have never done any 220V wiring before, but have done much research here and believe I understand everything.
Still, I thought I should post a photo of my setup and get comments before connecting my breakers.
I am using a Square D 70A QO load center. The neutral is not bonded. I added the ground bar as it did not come with the box. I will be installing 4 - 15A circuits.(2 - QOT1515 breakers). Two of these circuits will see minimal, if any use. I made sure all screws are very tight.
Does this look acceptable?
I found this board a few weeks ago while researching this project and it is a great help!
Thanks,
greg
gerG is offline   Reply With Quote
Old 07-09-2012, 09:56 AM   #2
Licensed electrician
Rewards Points: 1,750
You made the connections in the correct places. My issue would be when you said the screws are very tight. Very tight might mean too tight and might cause a conductor failure or a hot spot.
Old 07-09-2012, 10:44 AM   #3
Thanks for the reply Jim.
I appreciate your concern too.
They are a little more than just 'snug'.(My best quess at 40 in.lbs.)
I made sure not to crack any plastic or deform any connectors.
I sure don't want them too loose.
Yet another subpanel question md2lgyk Electrical 30 07-28-2011 08:19 AM
Yet another subpanel wiring question Chris_M Electrical 6 06-10-2010 05:12 PM
subpanel question Brik Electrical 2 11-30-2008 05:31 AM
Another subpanel question:) primal65 Electrical 15 06-22-2008 09:43 AM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 12:58 PM
