Subpanel For Now, Convert To 2nd Main Panel Later? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2009, 09:22 AM   #1
Question
Subpanel for now, convert to 2nd main panel later?
I just purchased a pre-1900s Victorian home with knob-n-tube wiring throughout that I'm beginning to replace. The home was at one point a double, divided between first and second floors. There are two meters at the house, and two 100 amp main panels in the basement.
Prior to me buying the house, the one meter socket was pulled and all lines were moved to one panel. So, at this point, I have one empty meter outside and one empty 100 amp panel in the basement. Currently I'll be living in the home and would like to keep everything on one main. Down the road, however, I'd like to duplex the house once again and would divide the electric between first and second floors.
So, my question is, would it be advisable to relocate the now empty main panel in the basement to the second floor, setting it as a 100 amp subpanel? Then, as I'm updating the knob-and-tube in the second floor (3 br, full bath, laundry with washer/dryer), it would all stem from this subpanel. Then, down the road when I would duplex the house, I could switch this subpanel over to a main panel on a seperate meter.
In my plan, the subpanel would be located in a second floor closet, on an exterior wall that is directly vertical from the basement main panel. At the moment, that wall is an open cavity that I could easily run line and/or conduit between the second floor and the basement. If this sounds like the ideal way to do it, what type of line should I be running? Also, would I run the subpanel at its full 100 amp, or 60?
abmiller67 is offline   Reply With Quote
Old 08-27-2009, 12:23 PM   #2
The closet could not be a clothes closet
In additon you need 30" clearance width for the panel - measure from either side or more centered/off center on the panel
And 3' clearance in front of the panel
The new feed (when run) is supposed to connect to the breaker (or a shutoff) within around 5' of entering the house
So if an overhead feed the panel should be near where that wire will enter
Maybe more to it then this, what I can think of right now
Old 08-27-2009, 01:44 PM   #3
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
You maybe able to do this, but, you will very likely need to use a external (outside) disconnect / breaker, so a panel or a meter combo is your service equipment.
There maybe other rules that apply to a rental type of situation that I don't know about.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Determining Main Panel Load with Subpanel added Randell Tarin Electrical 2 04-11-2008 01:21 PM
Replace main panel or use subpanel? MasterofNone Electrical 8 02-12-2008 12:24 AM
Add subpanel or upgrade main panel dcoz Electrical 1 01-12-2006 09:24 AM
