Subpanel Mounting? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2009, 06:12 PM   #1
Lake Forest, CA
Question
subpanel mounting?
Hey gang,
could use some guidance here.. I am routing the electrical from my panel to a sub panel that will service a hot tub.. Is there any restrictions on how the subpanel is mounted? I know it needs to be 5-15' from the water. I thought I would stand up a 4x4 post next to the brick wall and mount it there however the foundation for the brick wall will not allow me to put the post flush with the wall. Can I simply mount the subpanel directly to the brick wall? by the way.. it is my property line wall..
Thanks,
Jerid
SKINNY is offline   Reply With Quote
Old 05-29-2009, 06:51 PM   #2
Some times it's that simple
220/221 is offline   Reply With Quote
Old 05-29-2009, 07:09 PM   #3
Rewards Points: 2,350
Sometimes they are wild. You have to sneak up real slow. After circling around a few times to show you are interested, come back around an slowly get closer. When you are close enough jump on the subpanel and mount it. It may buck a little, but it calms quick enough. If there is a brick wall there, that is better, cause it can't get away.
Old 05-29-2009, 07:11 PM   #4
Just make sure it isn't "live" when you mount it
I prefer plywood, but it depends upon location
Plywood makes it easier to attach anything else that may be needed
Old 05-29-2009, 07:20 PM   #5
Lake Forest, CA
cool.. its going on the block wall..
Old 05-29-2009, 07:37 PM   #6
Thanks,
Jerid
But it is your wall?
Not a condo wall or common ownership wall?
Old 05-29-2009, 07:58 PM   #7
Lake Forest, CA
Ok, now your getting technical.. as if the wiring didn't scare me enough. LOL.. Honestly, I really don't know.. It is a wall between my property and the neighbors.. I suspect it's common ownership.. I'll make sure the screws don't go more than half way ..
Old 05-31-2009, 11:27 AM   #8
Rewards Points: 58
These work great and you do not need a sub panel. Required GFCI receptacle included.
Old 05-31-2009, 12:25 PM   #9
Lake Forest, CA
I found that home depot and lowes sell a spa specific load center with gfci included.. they run about 100 bucks..
Old 05-31-2009, 12:27 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
That is a smoking deal.
The breaker alone costs $100+
Old 05-31-2009, 02:37 PM   #11
" Euro " electrician
frenchelectrican's Avatar
Go for it as myself I know what the 2 pole GFCI breaker cost it useally over 100 + but for the spa subpanel now that is real good deal there.
Merci,Marc
Old 05-31-2009, 03:22 PM   #12
Merci,Marc
The day we start listing prices in America in Euros is the day I become a bush-crawling super sniper...
Old 05-31-2009, 03:28 PM   #13
Merci,Marc
Ok let me fix this $/ 100. now are you happy ?? that will take care both ways
Merci,Marc
Old 06-07-2009, 12:36 PM   #14
not to digress, but is it OK to double tap to a main feed ( given that the main panel is full, and cannot take any more breakers) when routing a line to a 240V sub panel?
banyan is offline   Reply With Quote
Old 06-07-2009, 05:32 PM   #15
99.999% of the time NO.
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 02:38 PM
Another subpanel question:) primal65 Electrical 15 06-22-2008 10:43 AM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 01:58 PM
