Subpanel Mount - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2008, 12:28 AM   #1
ifinew
subpanel mount
If i need to mount a subpanel in a detached garage with sheetrock on ceiling only as of now. when and if i have to mount it on sheetrock covered wall some of the existing wires through studs need to come through the back knockouts i guess, are there special wire retainers or protectors used.
can someone give some tips on this
also if it matters there is brick on the exterior
thanks for the great help
brmax is offline   Reply With Quote
Old 05-15-2008, 10:23 PM   #2
Master Of Nothing
mr500's Avatar
Go here. This is what most of the world uses. They make different sizes for the different knockouts.
http://www.homedepot.com/webapp/wcs/...3+90481+500158
Im Not An Electrician...But I Did Stay At A Holiday Inn Express Last Night!!
mr500 is offline   Reply With Quote
Old 05-16-2008, 06:29 PM   #3
ifinew
mr500
thanks for the picture, i think i have a few of them
Old 05-16-2008, 08:40 PM   #4
Electrician
Originally Posted by brmax View Post
mr500
Generally they are only listed for two cables per connector in case you were wondering...
chris75 is offline   Reply With Quote
Old 05-16-2008, 10:00 PM   #5
ifinew
chris75
thanks for the tip, i didnt know that. can i assume this with 10,12,14 guage typical sheathed nm cable.
i have heard the insulation should be 1/2" showing inside the panel.
Old 05-16-2008, 10:34 PM   #6
Electrician
chris75
Check with the manufacture to see what they allow for cables per connector, and yes 1/2" minimum sheath inside the panel.
Old 05-16-2008, 11:48 PM   #7
ifinew
thanks i will look into that
i have another question if your up to it
if i have a feeder in pvc conduit lb into stud cavity from outside and need to go over thru another 2 studs but the wire in conduit is to big can i split the feeders from a j box then go thru studs with smaller conduit?
this is just preliminary ?, the loads i have need to be calculated and then checked out
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Subpanel installation in outbuilding fls Electrical 19 03-16-2008 03:19 PM
Wiring 100A subpanel nebulous Electrical 9 08-29-2007 03:41 PM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 01:58 PM
