Subpanel Keeps Popping - Electrical - DIY Chatroom Home Improvement Forum
Old 04-04-2009, 05:02 AM   #1
subpanel keeps popping
On the main panel i have a one hundred amp breaker going to a subpanel. In the subpanel i have a forty amp breaker and a sixty amp breaker. The forty amp breaker is fine, never has popped: i have thrity amps going to the forty amp breaker. My problem is the sixty amp breaker keeps popping. The first time it popped was about six months ago. It popped one time six months ago and I never had any other issues until now. It keeps popping, after a few hours of being on, sometimes it popps in less than an hour and a half. I have forty amps total going to this sixty amp breaker. I took off the panel to the subpanel and see no issues with the wires, all the wires are all securly tightened into their respective places. The sixty amp breaker feels very warm to the touch, but not burniing your fingers hot. My next step is to take the sixty amp breaker and replace it. Hope this solves my dillema. Thank your for ready my post and i look forward to reading your thoughts.
helplake is offline   Reply With Quote
Old 04-04-2009, 05:17 AM   #2
Whatamess
If there is no apparent overload then I would replace it. They do go bad sometimes but not often.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 04-04-2009, 06:11 AM   #3
How do you know you are drawing 40A on that circuit, did you measure it?? There could be a problem with something plugged into that circuit.
Old 04-04-2009, 10:01 AM   #4
What is the 60 amp breaker feeding? Also, when/if you replace the breaker check the bussing or the "place where the breaker plugs into the panel" and see if it looks discolored or burnt. A poor connection may have caused some heat build up and burnt the bussing. If it is you will need to replace the panel, a new breaker wont help for very long. The good news is the breaker is tripping, so its doing its job.
unclduey is offline   Reply With Quote
Old 04-04-2009, 10:25 AM   #5
Average current value = 40A.
RMS value of periodic current spikes = 20+ A, giving over 60A RMS? You'd need a scope to see them, though, if they are there.
What is the voltage drop across the closed CB when 40A is being pulled? I'd think 60 mV or less is good, more than 160 mV is bad.
Old 04-04-2009, 11:47 AM   #6
Smile
popping breaker
Thank you so much everyone for your input. I will take your views into consideration. Have a nice day!
Old 04-05-2009, 11:43 AM   #7
Amp meter
Don't forget to throw a amp meter on that panel first to see what's happening. Go from there.
SULTINI is offline   Reply With Quote
Old 04-07-2009, 08:16 AM   #8
Rewards Points: 1,512
Breaker feels very warm?
Instantly take measures to cut down on the load. You could be frying the "place where the breaker plugs..." right now.
Then get it fixed as quickly as possible.
Tags
breaker pops
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
Another subpanel question:) primal65 Electrical 15 06-22-2008 09:43 AM
Wiring 100A subpanel nebulous Electrical 9 08-29-2007 02:41 PM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 12:58 PM
