SubPanel Installation Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2011, 10:47 AM   #1
New poster here, thanks for all of you at this site. From what I've seen so far, you all are wonderful.
I have a quick question on sub panel installation. I have an existing 125 amp main panel that feeds from a main breaker located outside. I am going to install a 60 amp subpanel that has main lugs (no main breaker). I just want to make sure I size the breaker (disconnect) that I put in my existing panel properly and the wire size is correct.
My plan is to put a 50 amp 220 breaker to feed the sub on #6 cable.
If I'm off base, or if anyone has better ideas, I would appreciate the help.
lowvolter is offline   Reply With Quote
Old 12-01-2011, 11:05 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Yes, 50 amp breaker on # 6 is ok.
Are the panels in the same building?
Old 12-01-2011, 11:18 AM   #3
Yep...they will actually be sitting right next to each other in my basement. The builder didn't put in a very big panel to begin with.
So I would put in #6 hot, #6 hot, #6 neutral and would I need a #6 ground?
Old 12-01-2011, 11:30 AM   #4
jbfan's Avatar
Rewards Points: 650
If you are allowed to use romex in you're area, then use 6/3 with a ground to connect the panel.
Make sure you have the neutral and ground seperate in the sub.
If you are using individual wires, then a #10 is all that is needed.
Old 12-01-2011, 11:39 AM   #5
Awesome...We are able to use Romex here so I will go that route. Thanks a ton for the response and knowledge!
This site just saved me a TON of money running my second panel to the outside box, which is what I thought my only option was...
Old 12-01-2011, 03:54 PM   #6
Rewards Points: 160
Do note: The #10 JB refers to is for the ground only! #6 for the conductors.
cgoll is offline   Reply With Quote
Old 12-01-2011, 04:12 PM   #7
good clarification...I was thinking that, and was watching the other post for a similar situation to make sure. Thanks for clearing that up in my mind.
Old 12-01-2011, 06:17 PM   #8
"So I Re-Wired It"
MisterZ's Avatar
jbfan mentioned isolating neutral and ground... also remove the bonding screw if it exists. this screw "bonds" the neutral to the ground.
you do not want this in a sub panel
MisterZ is offline   Reply With Quote
Yet another subpanel wiring question Chris_M Electrical 6 06-10-2010 05:12 PM
Young Artist with question about LED's for installation SX0T Electrical 16 06-10-2010 02:39 PM
Vinyl siding installation question Branden Building & Construction 2 06-01-2010 12:17 PM
To Subpanel or Not to Subpanel, That is the Question finnimus Electrical 8 03-05-2009 02:32 PM
subpanel question Brik Electrical 2 11-30-2008 05:31 AM
