Old 10-13-2012, 09:50 PM   #16
subpanel grounding 3-wire
Originally Posted by mpoulton View Post
The ground wire must be either green or bare. It cannot be black or any other color. If it's 10 gauge, then it must be copper. You could use aluminum but it would need to be larger, and it's weird to mix copper and aluminum in the same run. I would use solid bare copper.
would it be ok to run a bare solid copper wire thru the conduit, would the bare copper wire short to the conduit?
I just realized that this was a stupid question! since the ground bar kit would be screwed to the metal box to which the conduit is attached...
jeffrey mays is offline   Reply With Quote
2-2-4 SEU - Smaller Neutral? BRT Electrical 18 09-23-2012 10:25 PM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
running wire to a detached shed subpanel amakarevic Electrical 9 03-27-2008 06:15 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
