Subpanel Ground/Neutral Bars - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 06-18-2014, 02:21 PM   #46
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Originally Posted by DIYDS View Post
Wheres the bonding screw?
You need connectors for the wire where it enters the panel.
The Following User Says Thank You to jbfan For This Useful Post:
DIYDS (06-18-2014)
Old 06-18-2014, 02:32 PM   #47
Rewards Points: 1,832
Ok your good, the neutral isn't bonded. Your good. However, Jbfan is correct you need connectors where the wire comes in.
Jump-start is offline   Reply With Quote
Old 06-18-2014, 02:33 PM   #48
Its not bonded?
There is a screw there... It looks like the rest. I cant tell if it goes all the way through the panel though
DIYDS is offline   Reply With Quote
Old 06-18-2014, 02:58 PM   #49
Its not bonded?
Siemens panels generally bond via a strap that goes from the metal can into one of those screw. However, it looks like that strap is gone, which, being a sub panel is a good thing.
Old 06-18-2014, 03:00 PM   #50
Rewards Points: 3,256
Its not bonded?
Just to be sure, remove both screws (bond and ground). Once you remove them, look to see if they are long enough to screw into the enclosure. If so, leave them out.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
DIYDS (06-18-2014)
Old 06-18-2014, 03:12 PM   #51
I don't think he has to remove any screws, some Siemens, Murray and Cutler Hammer panels bond via a metal strap the bridges the can and goes over to the screw labeled "bond".
I mentioned screw because 2/3 of panels do it the other way. GE, QO, Homeline ect use a long screw that goes into the neutral bar that penetrates into the metal can.
Ill post pics
The Following User Says Thank You to Jump-start For This Useful Post:
DIYDS (06-18-2014)
Old 06-18-2014, 03:19 PM   #52
Ok this is the metal strap I was talking about:
DIYDS (06-18-2014)
Old 06-18-2014, 03:22 PM   #53
In the OPs case, this strap is removed which is correct. It shouldn't be present in a sub panel.
As for the ground bar its fine since its already touching the can and screwed in with metal screws. This is ok and the ground bar needs no bond screw or strap since its naturally bonded (not up on plastic like the neutral)
DIYDS (06-18-2014)
Old 06-18-2014, 03:46 PM   #54
That's fine, but removing 2 screws just to be sure is nice and easy. If you go back and look at the OP's pic of the neutral bar label it shows a ground screw at the bottom of the neutral bar. That is the other screw I wanted him to check. Maybe it just means to put the ground wire there, I don't know.
Old 06-18-2014, 03:57 PM   #55
No I checked it out.
If you want you can put a longer screw in there and it will touch the back of the panel.
It must be someway to contact the can.
Otherwise the bar is raised and the other screws only touch the inside of the bar and not the back of the can.
Theres no screw there at all though.
Everything is done except the connectors.
Are those just to keep people from pulling the wires loose?
Old 06-18-2014, 03:58 PM   #56
OK, good. Yes, to keep the cables from pulling out.
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Shed subpanel BrandonD Electrical 21 10-14-2012 12:06 PM
One or Two ground/neutral bars in loadcenter?? Johnd85053 Electrical 13 02-10-2012 12:11 AM
Subpanel Right Below Main dcapone Electrical 6 01-02-2012 04:46 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
