Subpanel Ground/Neutral Bars - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-18-2014, 04:41 AM   #31
It would be nice if there was a place on the interwebs where I could get some help.
What can I do to make sure an electrician does the job right?
DIYDS is offline   Reply With Quote
Old 06-18-2014, 04:48 AM   #32
Rewards Points: 3,256
Seriously man, this boneheaded idea is going to be hovering at the top of my list for a long time.
You know what needs to be done. Run a 4th wire and isolate the neutral/ground in the sub. If anyone suggests differently, it's going to be wrong.
zappa is offline   Reply With Quote
Old 06-18-2014, 04:52 AM   #33
Actually, I dont know what needs to be done - since Im not an electrician...
Thats why I came here... Not to be mocked for not being an electrician!
Everything I read says grounding can be the most confusing part of electricity. Im not sure why Im made fun of for not understanding everything about electricity. I came here for answers.
It has 4 wires if that includes ground.
Over the phone I mentioned to him about removing the bonding screw and he said something about putting a grounding rod in. He didnt have a look or anything.
Sounds like he didnt understand what I said, or I didnt understand him.
If all that needs to be done is removing the bonding screw thats cool. Ill make sure thats all he does.
Old 06-18-2014, 05:21 AM   #34
I have to run but the posts in your thread tell what needs to be done. Having the 4th wire changes everything for the better. I would also be suspect of that light ballast thing with the green neutral. If it positively for sure is 240 and not 240/120 then the green wire is most likely a ground.
Old 06-18-2014, 05:22 AM   #35
It is 220V and has a 110V trigger cable for a timer
Its ul approved and etl listed
Old 06-18-2014, 05:24 AM   #36
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Talked with an electrician who said he could just put a grounding rod in for the subs ground back at the main panel. That would separate them both at the main instead of modifying the sub. Would that be easier or better than just removing the bonding screw from the subpanel?
Ugh, no! Find yet another electrician that is knowledgable.
Old 06-18-2014, 05:26 AM   #37
OK good that you know this. The subject of ground rods has not come up yet but needs to be discussed. I really have to go.
Old 06-18-2014, 06:03 AM   #38
Its in the same building as the main panel. Its like 15 ft away. I dont think they need separate rods
The Following 3 Users Say Thank You to DIYDS For This Useful Post:
jbfan (06-18-2014), stickboy1375 (06-18-2014), zappa (06-18-2014)
Old 06-18-2014, 06:53 AM   #39
I hope you know that my comments were directed towards the electrician. I think everyone has been cordial and helpful to you. I was rushing to leave for work and I meant that your answers were already posted in this thread.
Old 06-18-2014, 06:59 AM   #40
Ok... so have the bonding screw removed and we are good. Nice...
I also noticed there was a bare ground wire going to neutral instead of ground. Thats fixed now.
One last question though...
Does the ground bar we installed on the panel need a riser kit? It didnt come with one
The wire going Down through the ground bar is the ground wire from the main panel
Old 06-18-2014, 07:49 AM   #41
The ground bar needs to be electrically connected to the pan with the proper screws so you are probably good to go.
Old 06-18-2014, 12:57 PM   #42
Rewards Points: 1,832
1 or 2 ground rods per structure. $ wires is correct. Bonding screw is removed. Any pics of the whole panel so I know what is going on for sure?
Jump-start is offline   Reply With Quote
Old 06-18-2014, 02:00 PM   #43
Wheres the bonding screw?
Old 06-18-2014, 02:05 PM   #44
Licensed electrician
Rewards Points: 1,892
The label inside the panel will show where the bond screw or strap goes.
Old 06-18-2014, 02:21 PM   #45
So its just the screw there in the front of the panel?
I thought the panel might have to be removed.
Does the pin need to be taken out of the bond and put into the ground, or just taken out completely?
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Shed subpanel BrandonD Electrical 21 10-14-2012 12:06 PM
One or Two ground/neutral bars in loadcenter?? Johnd85053 Electrical 13 02-10-2012 12:11 AM
Subpanel Right Below Main dcapone Electrical 6 01-02-2012 04:46 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
