Subpanel Ground/Neutral Bars - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-16-2014, 10:56 AM   #16
Originally Posted by jbfan View Post
Looks like you have grounds on the neutral bar.
Did you use romex, type nm-b cable?
Is the panel in an attached or detached location from the main panel?
You have to replace the cable feeding the panel with 4 wire.
You can't use the bare wire in the 3 wire cable for anything but ground.
Can you take a pic of the cable inside the box?
That green wire you see in the sub panel says NEUTRAL.
Its a 3 wire with Black white and green
DIYDS is offline   Reply With Quote
Old 06-16-2014, 11:05 AM   #17
Licensed electrician
Rewards Points: 1,020
The green is never to be used for a neutral. Neutrals are white or gray. Green is for grounding.
Old 06-16-2014, 11:12 AM   #18
The device is clearly marked neutral though. Theres no other wire
Old 06-16-2014, 11:21 AM   #19
Is the ground the 4th wire?
Anyhow, both ground and neutral are tied into the same bar at the main panel.
Hes supposed to fix it today, I just dont know what hes supposed to do, or know if he knows
Old 06-16-2014, 11:30 AM   #20
What was that a picture of?
Old 06-16-2014, 11:38 AM   #21
Thats the main panel outside of the garage.
The first pic shows the ground and neutral wires going to the same bar
I dont know where else he can put it
Old 06-16-2014, 12:59 PM   #22
If the ground and neutral are connected at the main panel does the bonding screw need to be removed from the neutral on the sub?
Old 06-16-2014, 01:24 PM   #23
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
What is this a picture of?
Old 06-16-2014, 01:25 PM   #24
jbfan's Avatar
Rewards Points: 140
Yes it does.
Old 06-16-2014, 07:04 PM   #25
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
These threads kill me... oh wait, kill someone else?
Old 06-16-2014, 09:44 PM   #26
Contractor
That makes more sense.
We only have the 3 wires feeding the subpanel.
Does it actually need ground and neutral separated?
The panel came with only the one bar
If I remember correctly in SUBPANELS Its code. Neutrals and grounds must be isolated from each other.
steveinNEPA is offline   Reply With Quote
Old 06-16-2014, 10:48 PM   #27
Its a 220V powerbox for a couple of ballasts
Old 06-16-2014, 10:54 PM   #28
Luckily Im not the one doing the work...
I just need to get it done!
Old 06-18-2014, 04:58 AM   #29
Talked with an electrician who said he could just put a grounding rod in for the subs ground back at the main panel.
That would separate them both at the main instead of modifying the sub.
Would that be easier or better than just removing the bonding screw from the subpanel?
Old 06-18-2014, 05:31 AM   #30
Rewards Points: 3,256
Get a new lectrician......Immediately. Don't even let him put a tool in his hand.
zappa is offline   Reply With Quote
The Following 4 Users Say Thank You to zappa For This Useful Post:
jbfan (06-18-2014), mm11 (06-18-2014), stickboy1375 (06-18-2014), Stubbie (06-18-2014)
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 02:33 PM
Shed subpanel BrandonD Electrical 21 10-14-2012 01:06 PM
One or Two ground/neutral bars in loadcenter?? Johnd85053 Electrical 13 02-10-2012 01:11 AM
Subpanel Right Below Main dcapone Electrical 6 01-02-2012 05:46 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 10:45 PM
