Subpanel Ground/Neutral Bars - Electrical - DIY Chatroom Home Improvement Forum
Old 06-16-2014, 05:51 AM   #1
Subpanel Ground/Neutral bars
My uncle put in a subpanel and him and brother argued about having a separate ground and neutral bar.
Is it supposed to be bonded to the panel or something?
I have some pics that Im not allowed to post until Ive made 5 posts.
DIYDS is offline   Reply With Quote
Old 06-16-2014, 05:52 AM   #2
The additional bar was just put into the can, so I assume they are both bonded
Old 06-16-2014, 05:52 AM   #3
Pics coming soon!
Old 06-16-2014, 05:53 AM   #4
Thanks for the help in advance!
Old 06-16-2014, 05:54 AM   #5
One more post until I can upload pics!
Old 06-16-2014, 05:55 AM   #6
Hows this supposed to be setup?
Old 06-16-2014, 06:08 AM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
The sub-panel requires to be fed by four conductors, Hot, Hot, Neutral, Ground. The neutral and ground must be separated in the sub panel, and the the panel itself needs to be bonded to the grounding conductor.
Old 06-16-2014, 06:10 AM   #8
That makes more sense.
We only have the 3 wires feeding the subpanel.
Does it actually need ground and neutral separated?
The panel came with only the one bar
Old 06-16-2014, 06:12 AM   #9
E2 Electrician
What wiring method did you use to feed the panel?
Yes, it actually DOES need the ground and neutral separated.
If you look at the panel label, they will list all the accessories available for your panel, one item will be a ground bar.
Old 06-16-2014, 06:15 AM   #10
its #6awg to the panel from the main panel
I guess we will have to run another wire from the bar to the main panel.
Old 06-16-2014, 06:17 AM   #11
E2 Electrician
But did you use a metallic raceway? If so, that counts as the 4th conductor.
Old 06-16-2014, 06:18 AM   #12
No, its just 3 wire romex
Is that how the bar is supposed to be installed, or is there a bonding screw that needs to be reomoved?
Old 06-16-2014, 06:24 AM   #13
Does the 4th wire connect at the same place at the main panel as my other ground wire?
Old 06-16-2014, 08:29 AM   #14
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Looks like you have grounds on the neutral bar.
Did you use romex, type nm-b cable?
Is the panel in an attached or detached location from the main panel?
You have to replace the cable feeding the panel with 4 wire.
You can't use the bare wire in the 3 wire cable for anything but ground.
Can you take a pic of the cable inside the box?
Old 06-16-2014, 09:33 AM   #15
nm-b 600
I dont see where to put the neutral
The sub is inside the garage and the main is just outside of the garage
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Shed subpanel BrandonD Electrical 21 10-14-2012 12:06 PM
One or Two ground/neutral bars in loadcenter?? Johnd85053 Electrical 13 02-10-2012 12:11 AM
Subpanel Right Below Main dcapone Electrical 6 01-02-2012 04:46 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
