Subpanel Ground Bar? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2012, 06:24 PM   #1
Subpanel ground bar?
Hello, I have a Siemens load center that I want to use as a 100 amp subpanel. The load center comes with a tiebar that connects the two insulated neutral bars together and a green "bonding" screw that can bond the right neutral bus to the panel's chassis.
It appears that this load center does not come with factory installed ground bars so I am curious whether I can remove the tiebar that connects the two neutral bars together and screw the bonding screw down to use that side for a ground bar?
I could buy a separate ground bar kit of course, but I would rather do the above if at all possible.
J_Young is offline   Reply With Quote
Old 06-01-2012, 06:51 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Specify the model number of the panel for a better answer but it sounds like it is doable.
Coastal South Carolina
Old 06-01-2012, 06:53 PM   #3
Model # G2020B1100CU and looks just like this panel: http://paragoninspects.com/images/te...panel-wide.jpg
Old 06-01-2012, 07:31 PM   #4
Master Electrician
Rewards Points: 3,918
Yes your plan is ok. However, the lugs on the buss will only accept up to a #4 conductor so, depending upon your feeder size, you may need to purchase an "add-a-lug" to accomodate the neutral conductor.
brric is offline   Reply With Quote
Old 06-01-2012, 07:44 PM   #5
Thank you for your response brric, I think it might be easier to just buy a 20 terminal position ground bar kit that comes with a ground lug that accepts up to 1/0 cable size which Siemens part # ECGB201 does. My grounding conductor will be a #6 THHN cable and the two hots and neutral will be #3 THHN cable so I'm thinking just buy the stupid ground bar kit and that gives me everything I need. It's good to know that my plan would have worked though. Thanks
Old 06-01-2012, 08:09 PM   #6
Just curious brric, is this what you mean by an "add-a-lug"? Siemens part # ECLK2 ?
Old 06-01-2012, 08:17 PM   #7
Sparky
Rewards Points: 510
yes, that would be the correct 'add-a-lug' for your panel
Techy is offline   Reply With Quote
Old 06-01-2012, 08:17 PM   #8
Master Electrician
That would be it.
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
Subpanel and grounding seismichippo Electrical 3 04-30-2011 07:53 PM
Attach #4 Copper to Neutral/ Ground Lug Sierevello Electrical 3 01-29-2011 01:04 AM
Grounding requirement for 100A subpanel blakeasaurus Electrical 2 12-08-2010 05:59 PM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 06:49 AM
