Old 08-22-2012, 09:12 PM   #31
Subpanel Feed
Originally Posted by stubie View Post
It looks fine to me ....... I also use the nice bends on the conductors to both the breakers and neutral/ground bars. There are a few things I would have done differently but I'm not going to beat you up over them as they are not code violations. Nice job.
What would you have done different?? I ask, as its the first subpanel that i've put in and I'm happy to learn what I should do different in the next one...
ryan50hrl is offline   Reply With Quote
Old 08-22-2012, 09:12 PM   #32
Subpanel Feed
Anyone have an answer for this???
Proper way to protect wire
Thanks again in advance guys!!
Old 08-22-2012, 10:42 PM   #33
Subpanel Feed
Can someone paste the NEC code relating to grounding of a subpanel? Is the main panel ground wire sufficient or does the OP need another ground wire to the grounding rod?
Bugman1400 is offline   Reply With Quote
Old 08-22-2012, 10:47 PM   #34
Subpanel Feed
As far as I understand the NEC, as its in the same building (20 feet away), I don't need anything other than a main panel ground.
Old 08-22-2012, 10:51 PM   #35
Licensed electrician
Subpanel Feed
No ground rod is needed in an attached building.
Old 08-22-2012, 11:15 PM   #36
E2 Electrician
stickboy1375's Avatar
Subpanel Feed
A ground rod serves no purpose in clearing a fault...
stickboy1375 is online now   Reply With Quote
Old 08-23-2012, 11:04 AM   #37
Subpanel Feed
Okay to run my feeder in here correct? I really hope so since I knocked a hole in it and put it through
Old 08-23-2012, 10:22 PM   #38
UAW SKILLED TRADES
Stubbie's Avatar
Subpanel Feed
Yes, you have to get power somewhere ..
Old 08-23-2012, 11:09 PM   #39
Subpanel Feed
Lol. Well ya, I was just looking to ensure there's no code requirements about where it enters
Old 08-24-2012, 12:20 AM   #40
UAW SKILLED TRADES
Stubbie's Avatar
Subpanel Feed
Its fine
Subpanel Right Below Main dcapone Electrical 6 01-02-2012 05:46 PM
Detached Garage Subpanel + Generator Back Feed insaneirish Electrical 3 09-06-2011 03:09 AM
splicing in a subpanel using lines that feed main breakers? lettcco Electrical 7 09-11-2010 09:16 AM
subpanel feed and conduit. chase237 Electrical 3 07-08-2010 10:35 AM
feed to subpanel question JCA1 Electrical 1 03-11-2008 09:16 PM
