Subpanel Feed - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2012, 04:01 PM   #1
Rewards Points: 164
Subpanel Feed
Hey guys.....running to get cable.....6/3 NM is good for my 60 amp subpanel right? All in the house, just 20 feet away from the main panel.
ryan50hrl is offline   Reply With Quote
Old 08-16-2012, 04:02 PM   #2
Master Electrician
Yes it is
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-16-2012, 04:07 PM   #3
Rewards Points: 164
Thanks........bound and determined to get this finished this weekend......I want my shop back...
Old 08-16-2012, 04:21 PM   #4
Rewards Points: 164
Ok, so as you can see my main panels kind of full. Is it okay to bring my subpanel feed in through the bottom left corner and then just staple it up the plywood next of the box
Subpanel Feed-image-2136531126.jpg   Subpanel Feed-image-3482235347.jpg   Subpanel Feed-image-517393580.jpg
Old 08-16-2012, 05:04 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
How are you going to power your subpanel with a full panel now?
Old 08-16-2012, 05:09 PM   #6
Rewards Points: 164
two circuits are moving to my subpanel.....
Old 08-16-2012, 05:53 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
6/3 with ground is ok .... It's good for 55 amps but you can use a 60 amp breaker since there is no standard 55 amp breaker.
Old 08-16-2012, 09:37 PM   #8
Rewards Points: 164
K, how about running the cable through the side?
Old 08-16-2012, 09:49 PM   #9
Missouri Bound's Avatar
How are you getting them there?
Do you want it your way or the right way?
Old 08-16-2012, 09:52 PM   #10
UAW SKILLED TRADES
Stubbie's Avatar
That's fine as long as you don't put a real sharp bend in it. Looks like you have the clearance necessary to come in from the side.
Old 08-16-2012, 10:07 PM   #11
Rewards Points: 164
Just running new furnace and waterheater circuits, why do you ask??
Old 08-16-2012, 10:09 PM   #12
Since you weren't running the wire in conduit I was wondering how you were doing it.
Old 08-16-2012, 10:13 PM   #13
Rewards Points: 164
Nope......just running new nm from the sub to the waterheater and furnace nothing except the dryer and washer are run in conduit.....
Old 08-16-2012, 10:16 PM   #14
Master Electrician
Why would he have to use conduit unless he's in Ill. Unless there's other areas that require it in the states as well. I don't get where your going with this either lol. 6/3 to subpanel and new circuits to replace the circuits he's taking out to make room for the sub feed. Seems ok to me.
Old 08-16-2012, 10:24 PM   #15
Rewards Points: 164
Am i missing something???
Subpanel Right Below Main dcapone Electrical 6 01-02-2012 04:46 PM
Detached Garage Subpanel + Generator Back Feed insaneirish Electrical 3 09-06-2011 02:09 AM
splicing in a subpanel using lines that feed main breakers? lettcco Electrical 7 09-11-2010 08:16 AM
subpanel feed and conduit. chase237 Electrical 3 07-08-2010 09:35 AM
feed to subpanel question JCA1 Electrical 1 03-11-2008 08:16 PM
