Subpanel Enclosure Framing - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2010, 09:13 AM   #1
I ask the impossible!
Rewards Points: 704
Subpanel enclosure framing
Just wanted to post a diagram of what I have planned to see if there's anything wrong with this plan.
I was planning to surface mount the panel and run cables down from the ceiling inside 3/4" PVC conduit, and I'd attach to the service panel with adaptors, but I'm running 10 circuits and I was thinking I'd put 4 conduits so I could leave open capacity for expansion later... So, I did some searching around and was reading about de-rating cables that is required in certain circumstances when you run multiple cables in conduit, I decided I'd rather just avoid the hassle of sorting that out...
So I came up with this enclosure from 2x4's in the diagram shown below, which I'll attach over the existing wall in the utility room and enclose with drywall after rough inspection.
Does this plan sound appropriate, and out of curiousity I'd be interested to hear if anyone can explain if there was anything wrong or if the de-rating doesn't apply if the run was just a 21" conduit run to where it penetrated a drywall ceiling? I might need to figure that one out anyway because the main panel is surface mounted, I've run 2 cables to it (sub-panel feeder and smoke detector circuit) so far each cable has its own conduit, but I could see needing to run something into that main panel might come up.
WillK is offline   Reply With Quote
Old 12-20-2010, 09:26 AM   #2
Licensed electrician
Rewards Points: 1,752
That mounting method would not be considered surface mounted to allow you to use the sleeves to get the cables into the panel. I would just run the cables directly into the panel. For the future you could run a conduit out and place an accessible junction box with a blank cover.
Old 12-20-2010, 09:42 AM   #3
Rewards Points: 704
Did I get wordy again?
The sub-panel I'm putting in, I was originally planning to surface mount, but to avoid potential de-rating issues I changed to this enclosure so I wouldn't need conduit and wouldn't need to deal with things I'd need to deal with if it was surface mounted.
The main panel is surface mounted... Although your response got the wheels turning in my head... "maybe if I needed to do anything with the main panel, I should just build it a similar enclosure as well."
Old 12-20-2010, 10:22 AM   #4
Master Electrician
Rewards Points: 3,916
Two vertical studs spaced apart by the width of the panel is more than adequate. Sleeves 24" or less preclude derating.
brric is online now   Reply With Quote
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 01:56 PM
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 08:44 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
